movie not finishing
jonass
movie not finishing
#1 Post by jonass » Sun May 20, 2012 2:25 am
I was trying to rip true grit and the movie stops at 87% done each time, any ideas why? I'm on win7 and using makemkv v1.7.4, it has always worked before and i didn't change any settings on it so I'm not sure what the problem is.
Re: movie not finishing
#2 Post by Woodstock » Mon May 21, 2012 12:50 am
What errors (if any) are displayed?
At the very least, you need to turn on debugging while doing the rip. Follow the Troubleshooting FAQ at http://www.makemkv.com/faq/item/8/catid/6 for how to do it, and what to submit.
For what it is worth, I was able to rip "a" DVD version of True Grit a few months ago, but there are several different ones out there.
