Just purchased a Verbatim 43890
HSH1979
#1 Post by HSH1979 » Thu Oct 08, 2026 7:12 pm
Hello all!
I'm waiting for this unit to be delivered, found at a very good price around 100€
What should i do to rip 4k uhd? is there a noob guide?
zittrig
Re: Just purchased a Verbatim 43890
#2 Post by zittrig » Thu Oct 08, 2026 7:32 pm
A flashing guide you can find here viewtopic.php?t=19634
But it matters if your 43890 contains a LG BU40N or a Pioneer BDR-UD03. Post your MakeMKV drive info when it's arrived.
HSH1979
#3 Post by HSH1979 » Fri Oct 09, 2026 7:38 pm
can i know the difference?
is one better or the other?
zittrig
#4 Post by zittrig » Fri Oct 09, 2026 11:07 pm
The BDR-UD03 can be flashed to BDR-UD04 and it is the slightly better drive but hard to be found nowadays. And you can only flash the LG variant by yourself with the SDF Flasher and the firmware pack which can be found in the link above. For the Pioneer variant you should ask for flashing support here and someone will help you.
HSH1979
#5 Post by HSH1979 » Sat Oct 10, 2026 1:21 pm
zittrig wrote: Fri Oct 09, 2026 11:07 pm The BDR-UD03 can be flashed to BDR-UD04 and it is the slightly better drive but hard to be found nowadays. And you can only flash the LG variant by yourself with the SDF Flasher and the firmware pack which can be found in the link above. For the Pioneer variant you should ask for flashing support here and someone will help you.
someone wull help you.. meaning i gotta pay for it, so if i got the pioner i will send it back....
#6 Post by Billycar11 » Sat Oct 10, 2026 1:24 pm
HSH1979 wrote: Sat Oct 10, 2026 1:21 pm
someone wiull help you.. meaning i gotta pay for it, so if i got the pioner i will send it back....
Pioneer flashing is now free see guide below
HSH1979
#7 Post by HSH1979 » Mon Oct 19, 2026 7:49 am
thanks guys!
and what about a BDW-PR1EPDVPP100 or better BDE-PR1EP
is this flashable or better to avoid it?
Yethidran
#8 Post by Yethidran » Mon Oct 19, 2026 9:25 am
if your adventurous, and willing to take risks, then try this firmware from MattJackson's Pioneer Firmware Page attached below..
https://freemkv.org/firmware/find/
Yethidran
#9 Post by Yethidran » Mon Oct 19, 2026 9:30 am
Type in the "SearchBox" for "BDE-PR1"
You will see 2 models come up..
Download his "Flasher" too.. Simple and fool proof. remember to do a "BackUp and also do a Dump" before you flash it.
HSH1979
#10 Post by HSH1979 » Mon Oct 19, 2026 10:01 am
Yethidran wrote: Mon Oct 19, 2026 9:30 am Type in the "SearchBox" for "BDE-PR1"
Thanks! Which one of the 2 shall i pick?
Yethidran
#11 Post by Yethidran » Mon Oct 19, 2026 10:10 am
Since it will be a "Calculated Risk on your part, and you fully understand the risks" i would say any of the 2, or you could also try both..
remember to back up and also to dump the firmware before you press the button to flash!!
if i had those drives in my own hands i would just "Proceed and try my luck"
there is also a "Recovery Button" in his flasher to do the work if need be.
i have been flashing everything in my hands with his flasher and the extensive list of ever growing "1500 Pioneer Firmwares to choose from" Hehehehehe!!
heisenberg
#12 Post by heisenberg » Mon Oct 19, 2026 10:48 am
HSH1979 wrote: Mon Oct 19, 2026 10:01 am
Not sure which flashers you are referring to, however, for what it is worth, BDRFlash++ is capable of crossflashing both the BDW-PR1EPDV and the BDE-PR1EP. (which is why I am selling these (crossflashed) drives in the sellers forum). I'm definitely biased, but I’d honestly recommend BDRFlash++ or Matt’s Flasher since both are totally free to use and were built right from scratch.
Do you want to crossflash your Pioneer drive with UHD-compatible firmware? Check out BDRFlash++ here.
Looking for a 4K UHD Pioneer drive from the BDRFlash++ developer? Check out this thread.
Yethidran
#13 Post by Yethidran » Mon Oct 19, 2026 10:52 am
Thanks for offering your help too buddy.. its really a great field day for Pioneer owners!!
2 Absolutely Free Pioneer Flashers being offered for Free Use for anyone and everyone!!
Yethidran
#14 Post by Yethidran » Mon Oct 19, 2026 11:14 am
its totally fine to be "biased" buddy, its just that i really am not familiar with this "CLI or Terminal Thingy"
That's the reason i leaned more, and am definitely more comfortable with Matt's App.. just press buttons, choose firmwares conveniently from his extensive firmware page and see if it can be crossflashed, downgraded, sidegraded, upgraded...Hehehehe!!
HSH1979
#15 Post by HSH1979 » Mon Oct 19, 2026 1:53 pm
ok so ill give a try with BDE-PR1, i found 2 units at 60€ , if they work fine i could also resell one after flashing and testing
