Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
#4006 Post by Billycar11 » Wed Sep 30, 2026 3:09 pm
Tsunamijhoe wrote: Wed Sep 30, 2026 2:47 pm OK, i did read post 1, but there is so much information, and i am uncertain if i can just use the sfd flasher tool, and which firmware i need to use or if this needs to be flashed to asus first or something because of downgrade protection?
I recommend you reach out to me or Marty for assistance then
That's why we offer this service
Giklab
#4007 Post by Giklab » Wed Sep 30, 2026 5:56 pm
Hi all!
I'm preparing to flash my drive and would like to verify that I'm not doing anything stupid. The drive is an Asus BW-16D1X-U (5.25" in an enclosure), Revision A105 and Platform MT1959.
From what I understand, I should first flash it to Asus 3.10MK, then the LG 5.25" firmware on top of that, both from the "All you need" pack? Would just like to doublecheck before I nuke my drive :D Thanks in advance.
#4008 Post by MartyMcNuts » Thu Oct 01, 2026 1:34 am
Giklab wrote: Wed Sep 30, 2026 5:56 pm Hi all!
Flash directly to WH16NS60 1.02-MK.
ulop3
#4009 Post by ulop3 » Thu Oct 01, 2026 2:26 pm
Hi there, I am trying to flash my LG BH16NS55
I am on Linux (NixOS, nix package of MakeMKV 1.18.4) where I tried using makemkvcon with sdf.bin.
makemkvcon f -d location --info
Showed the drive info correctly.
OS device name: /dev/sr0
Product: BD-RE BH16NS55
Revision: 1.03
Serial number: XXXXXXX
Firmware date: 2117-11-20 17:04
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.03
But trying to dump the firmware didnt work at all:
makemkvcon f -d location -f /home/user/Downloads/sdf.bin dump auto -o .
also not with sudo. It never gave any output, also not in dmesg. Not when giving it an absolute directory like /home/user/Downloads/ or when giving it a filename to write into. The "sg" kernel module was loaded and the drive can be used to rip 1080p blurays at 6x speed.
Now I tried on windows 11 with MakeMKV 2.0.0. The GUI SDFtool latest version didn't work. It looks like it tries to find the sdftool exe in the english directory while my system is german? No idea how windows works there.
I then used the manual way, which only works in a powershell window as administrator, not as normal user. I was not able to give it a custom output dir but was able to dump the user firmware to the current directory.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f -d J: dump -o .
Command produced 1 file(s)
  #00: size=70Kb name=dump_user_HL-DT-ST_BD-RE__BH16NS55_1.03_211711201704_KLMJ1BD3939.tar
Note that this is only the user firmware! I tried a full dump which failed.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f -d J: dump full -o .
Error: full dump is disabled in this firmware version
DEBUG: Code 4279205893 at xZ.-xCs_\J9DIbU=f*hi}nH>ad6F+b$,:29395034
Command produced error code 0xff0f8005
I do not feel comfortable flashing a custom firmware if a full dump does not work. Also, would it even work in this case? Do I need to downgrade the firmware?
And what could go on with Linux?
Thanks in advance!
Giklab
#4010 Post by Giklab » Thu Oct 01, 2026 4:46 pm
MartyMcNuts wrote: Thu Oct 01, 2026 1:34 am
I got an error (0x82062900) after flashing, but MAKEMKV recognised the drive right away and is currently happily backing up a disc. Thank you!
WunderWagen
#4011 Post by WunderWagen » Sun Oct 04, 2026 10:04 pm
Hello Billycar,
I tried reaching you through the gmail address... interested in buying a UHD drive for ripping and prefer to get one from you already set up. Can you please contact be for buying a ready made drive?
Also, I see most of the recommended models are optical drive writers... but for MakeMKV we should only need a reader correct? I tried searching on this and could not find anything specifically answering that question. :?
sbuxreg
#4012 Post by sbuxreg » Tue Oct 06, 2026 9:22 pm
Can anyone provide me with any assistance with my drive?
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.00
Serial number: OADL013760UC
Firmware date: 2014-07-30
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.00/ID34
#4013 Post by Billycar11 » Tue Oct 06, 2026 10:50 pm
sbuxreg wrote: Tue Oct 06, 2026 9:22 pm Can anyone provide me with any assistance with my drive?
OS device name: H:
Revision: 3.00
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
bergsal
#4014 Post by bergsal » Wed Oct 07, 2026 3:47 am
Hi, I'm trying to flash my drive:
Product: BD-RE BU50N
Revision: GE03
Serial number: MO5J86G3647
Firmware date: 2119-04-23 16:48
Bus encryption flags: 1F
Highest AACS version: 35
I've followed the guide and found forum posts that suggested I treat the BU50N as BU40N. I'm running arch linux and installed makemkv through the yay package, downoaded ./makemkvcon bin, sdf.bin and /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
I run:
~/Downloads/makemkv-bin-1.17.7/bin/amd64/makemkvcon f \
                                                              -d /dev/sr0 -f /tmp/sdf.bin \
                                                              -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
and get the error:
No drive tool logic found in SDF.bin
Internal error 0x8d000000
I tried the troubleshooting step of inserting a bluray and it can recognize and read the disc.
Then I tried to override the auto detect:
                                                              -d /dev/sr0 -f /tmp/sdf.bin -t mtk19xx rawflash enc \
And I get the error:
Reading input file /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Unable to read current bootloader version, trying to proceed without one...
Current Drive ID: HL-DT-ST_BD-RE_BU50N_GE03_211904231648_MO5J86G3647
DEBUG: Code 117637252 at ),_s4zL&yiok<4o@JLf1am'D=Ct{fox-:213132261
Desktop drive handshake failed with error=0x07030084, trying slim drive handshake...
DEBUG: Code 4280373253 at ),_s4zL&yiok<4o@JLf1am'D=Ct{fox-:213133503
Command produced error code 0xff215005
Anyone know how to fix this issue? I've seen some suggest that my cable is not passing through flashing commands.
#4015 Post by Billycar11 » Wed Oct 07, 2026 7:16 am
bergsal wrote: Wed Oct 07, 2026 3:47 am Hi, I'm trying to flash my drive:
Revision: GE03
I run:
and get the error:
please dont double post about this all around
as i said no enc in the other page
musashiwrx
#4016 Post by musashiwrx » Wed Oct 07, 2026 3:22 pm
Morning All,
Been lurking here for years and have bought several full size drives. I think my Pioneer came from Billycar11.
I've been buying 'disposable' LG slims from best buy, flashing, ripping 250-300 disks, and then they die.
Any word on if the newer ASUS BW-16D1HT (1.10)full size drive is still flashable?
I dont actually know what the sellers mean by 1.10
#4017 Post by Billycar11 » Wed Oct 07, 2026 9:11 pm
musashiwrx wrote: Wed Oct 07, 2026 3:22 pm Morning All,
No Asus 1.xx is not flashable if it's LG
Feel free to email me the drive info and I can tell you if it's flashable or not
Mr_Orange
#4018 Post by Mr_Orange » Wed Oct 07, 2026 10:08 pm
Billycar11 wrote: Wed Oct 07, 2026 9:11 pm
This isn't what the guide says. It states any firmware to 3.10MK.
#4019 Post by Billycar11 » Wed Oct 07, 2026 10:14 pm
Mr_Orange wrote: Wed Oct 07, 2026 10:08 pm
the guide also says mt1959 is required as well as 2016+ build date
so any asus with mt1959 and 2016+ to that fw is correct
the problem now is all the fakes make this way more confusing
they are their own product line now like 1/4 of my emails are about fake drives
musashiwrx
#4020 Post by musashiwrx » Thu Oct 08, 2026 2:21 pm
Billycar11 wrote: Wed Oct 07, 2026 10:14 pm
Interesting. Well I've ordered a drive. I'll check it for whether it's fake or not before I do any flashing attempts. And if it's alright, I can email you, if you are cool with that. It's returnable. So no big deal really.
What did the comments about 'Asus if it's LG?' Asus is Asus, no?
