Public KeyDB Disc Submissions
r3vuluti0n
Disc type: UHD
Drive: BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Disc dump filename: MKB20_v65_The_First_Purge_4A8D
MKB_RO.inf link from disc: https://drive.google.com/file/d/1zguDTX ... drive_link
Disc dump link: https://drive.google.com/file/d/1pIlxOf ... drive_link
Disc dump filename: MKB20_v61_The_Purge-_Anarchy_4535
MKB_RO.inf link from disc: https://drive.google.com/file/d/1Nzqllh ... drive_link
Disc dump link: https://drive.google.com/file/d/1G7f4No ... drive_link
Disc dump filename: MKB20_v76_The_Forever_Purge_D623
MKB_RO.inf link from disc: https://drive.google.com/file/d/10W4bOU ... drive_link
Disc dump link: https://drive.google.com/file/d/1SMnxQ6 ... drive_link
Disc dump filename: MKB20_v61_The_Purge_5E7B
MKB_RO.inf link from disc: https://drive.google.com/file/d/1VbNQ77 ... drive_link
Disc dump link: https://drive.google.com/file/d/1w9VFe3 ... drive_link
Disc dump filename: MKB20_v61_The_Purge-_Election_Year_F4B5
MKB_RO.inf link from disc: https://drive.google.com/file/d/1wySDC2 ... drive_link
Disc dump link: https://drive.google.com/file/d/1ivXR-T ... drive_link
Drive: BU40N
r3vuluti0n
Disc type: UHD
Drive: BU40N
Disc dump filename: MKB21_v70_Zombieland_0C05
MKB_RO.inf link from disc: https://drive.google.com/file/d/1tm1AgN ... drive_link
Disc dump link: https://drive.google.com/file/d/1SzlQCO ... drive_link
Disc dump filename: MKB20_v77_UHD_KNDH_8069
MKB_RO.inf link from disc: https://drive.google.com/file/d/1ktR3Ie ... drive_link
Disc dump link: https://drive.google.com/file/d/15eGfT9 ... drive_link
Disc dump filename: MKB20_v77_Scream_3_(Remastered)_A81B
MKB_RO.inf link from disc: https://drive.google.com/file/d/1FuMubv ... drive_link
Disc dump link: https://drive.google.com/file/d/1hiA_2v ... drive_link
Disc dump filename: MKB20_v76_Uncharted_6131
MKB_RO.inf link from disc: https://drive.google.com/file/d/1vsETCv ... drive_link
Disc dump link: https://drive.google.com/file/d/1s5m9eN ... drive_link
Disc dump filename: MKB20_v61_unkn0wn_29FB
MKB_RO.inf link from disc: https://drive.google.com/file/d/14vT8tW ... drive_link
Disc dump link: https://drive.google.com/file/d/1lnQ5eT ... drive_link
Drive: BU40N
keydb_helper
Thanks for the clarification. I normally have to wait for a duplicate submission to find out the MakeMKV disc ID.
Thanks for the submissions r3vuluti0n, but this disc dump was the only one which could be added to the public keydb. The others seem to have been created from folders instead of the physical disc and disc dumps created like this do not contain the required data for key generation.
If you still have access to the physical discs, please initiate a protected backup for each disc. You can cancel the backup once the discatt.dat/discattd.dat file has been created. If you can then pass along those new discatt files the remaining AACS 2.0 discs can be added to the public keydb.
The required details for this disc are already known, so don't stress about generating a new discatt file for Zombieland. The public keydb doesn't currently support AACS 2.1.
Hey Barley, you can generate a 'synthetic disc dump' by following the process I outlined in the latter part of this post: LinkBarley wrote: Mon Oct 05, 2026 9:51 pm I'm encountering an issue where MakeMKV can read my UHD, but the disc is not in the keydb.cfg file. Therefore, there is no MakeMKV disc dump. However, I would like the keys to be added to keydb.cfg. Usually, I use KeyDB Assistant Synchronize-->Disc Info, and it finds the keys and updates the keydb.cfg file. However, this process is not working for my disc. Are you able to help if I don't have a disc dump file?
As I mentioned to r3vuluti0n, please make sure you use the physical disc as a source for this process.
Thanks for the kind words LondonCity, it is great to hear you've found the public keydb to be helpful.LondonCity wrote: Tue Oct 06, 2026 6:19 pm Thank you so much for creating and maintaining this post! KeyDB really helped me out on getting access to some of my UHD discs since I recently started backing up my BluRay collection.
If I come across any rare UHD discs with an unkown volume key, I will make sure to post it here. Again, this post (and the whole forum in general) is much appreciated![]()
Cheers from Germany.
r3vuluti0n
Sorry, I am learning. These are now fresh from disks
Is there a way to tell if a disk has AACS 2.1?
Disc type: UHD
Drive: BU40N
MKB_RO.inf link from disc: https://drive.google.com/file/d/10zzaeC ... drive_link
Disc dump link: https://drive.google.com/file/d/177eY1q ... drive_link
MKB_RO.inf link from disc: https://drive.google.com/file/d/1ndMynQ ... drive_link
Disc dump link: https://drive.google.com/file/d/15SSVgD ... drive_link
Disc dump filename: MKB20_v77_Back_To_Black_F6B1
MKB_RO.inf link from disc: https://drive.google.com/file/d/1CAHxcx ... drive_link
Disc dump link: https://drive.google.com/file/d/18hQ9Tx ... drive_link
Disc dump filename: MKB20_v61_Die_Unfassbaren_1_UHD_CD5D
MKB_RO.inf link from disc: https://drive.google.com/file/d/190khFo ... drive_link
Disc dump link: https://drive.google.com/file/d/12sI68_ ... drive_link
Disc dump filename: MKB20_v61_Die_Unfassbaren_2_UHD_CB9F
MKB_RO.inf link from disc: https://drive.google.com/file/d/1hmVTjq ... drive_link
Disc dump link: https://drive.google.com/file/d/1D_QGHL ... drive_link
Disc type: UHD
Drive: BU40N
Yeah, it would say MKB21. Just so you know, there are only about half a dozen titles that have AACS 2.1r3vuluti0n wrote: Wed Oct 07, 2026 2:48 am Sorry, I am learning. These are now fresh from disks
Disc type: UHD
Drive: BU40N
keydb_helper
No worries r3vuluti0n. Thanks for the quick follow up. Those five discs have been added to the public keydb.r3vuluti0n wrote: Wed Oct 07, 2026 2:48 am Sorry, I am learning. These are now fresh from disks
When you get a chance, it would be appreciated if you could revisit these six discs:
As Marty noted there were only a small number of titles which utilised AACS 2.1 and the disc dump file name will indicate the AACS version. I think it has also been at least 5-6 years since the last AACS 2.1 disc was released.
Barley
Disc type: UHD
Drive: BDR-S11JX
Drive firmware: 1.53
Disc dump filename: MKB20_v76_Back_to_the_Future_Part_II_2D5B
MKB_RO.inf link from disc: https://drive.proton.me/urls/8BEDD8938W#UvLScQbYm5Dj
Disc dump link: https://drive.proton.me/urls/PA68VXSW04#Nkg8v4FUQzAi
Disc dump filename: MKB20_v76_Back_to_the_Future_Part_III_E741
MKB_RO.inf link from disc: https://drive.proton.me/urls/X4WQ1TBQZG#qq3FPt8cmkzL
Disc dump link: https://drive.proton.me/urls/7MJVYJ1HXG#5v5Y4P3FDMTJ
Drive: BDR-S11JX
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_BRING_IT_ON_2000_A12C
snl20
My submisson of
The Cable Guy (1996) 4K Steelbook
bought in Norway and delivered 1 day after release date 06/10/2026
Label: CABLE_GUY_THE
Disc type: UHD
Disc ID: 0xC35CAA444704CF47D279AD9CBC2256C798CD14DD
Disc dump filename: MKB20_v82_Cable_Guy_E612
Drive: PIONEER BD-RW BDR-S12U
Drive firmware: 1.01
MKB_RO.inf link: <disc added>
Disc dump link: <disc added>
dvdfab does not read this yet but have received a dump and says it will be added
Disc type: UHD
keydb_helper
Thanks for the submission snl20. Your disc has been added to the public keydb.snl20 wrote: Wed Oct 07, 2026 2:47 pm Disc type: UHD
dagwed
Disc type: UHD
Disc ID: 107d1cfa4dfdd88e3bdc8a303f988ab6863e9d57
Disc dump filename: MKB20_v70_MARVEL'S_THE_AVENGERS_DA57
Drive: BU40N
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.google.com/file/d/1UkjCn2 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1t3rjLO ... sp=sharing
Drive: BU40N
dagwed
Disc type: UHD
Disc ID: 666e703c4bca4324e34f66235862639160e33d79
Disc dump filename: MKB20_v61_MARVEL'S_AVENGERS-_INFINITY_WAR_CB03
Drive: BU40N
MKB_RO.inf: https://drive.google.com/file/d/1uLUU0K ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1MPjbVB ... sp=sharing
Drive: BU40N
dagwed
Disc type: UHD
Disc ID: 36501dd663a27d70264881571bc800f638be5fbe
Disc dump filename: MKB20_v68_MARVEL'S_AVENGERS-_ENDGAME_DF1B
Drive: BU40N
MKB_RO.inf: https://drive.google.com/file/d/1igpRF_ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1fs7S3j ... sp=sharing
Drive: BU40N
keydb_helper
dagwed wrote: Wed Oct 07, 2026 3:40 pm Disc type: UHD
Disc ID: 0x21F69ABFCEB603AB41FC30D09005DABFC5B5678C
dagwed wrote: Wed Oct 07, 2026 3:45 pm Disc type: UHD
Disc ID: 0xE86FCAE4000784B3AF3370C92904C415E17D0300
Thanks for the new disc dump files dagwed. All three discs have been added to the public keydb.dagwed wrote: Wed Oct 07, 2026 3:50 pm Disc type: UHD
Disc ID: 0xF9F9D9069284741579BFB7D4930ADFBE23D12C87
RandomSelf
Dump submitted - Classe moyenne (2025) (Antony Cordier) [6B18]
Greetings all,
Disc type : HD
Disc ID : C3E6A93E23A5B751A45270BACEF808AC5C8E6F7B
Disc dump filename : MKB_v82_CLASSE_MOYENNE_6B18
Drive : BD-RE BH16NS40
Drive firmware : 1.05
LibreDrive status : Enabled
Did you sync the public keydb within the last 15 minutes : Yes
Submission links are accessible in incognito/private browsing : Verified
MKB_RO.inf link : https://drop.chapril.org/download/0fc44 ... kYsXQpLsxg
Disc dump link : https://drop.chapril.org/download/841f3 ... ak8Dm38CJw
All the best,
Greetings all,
Disc type : HD
All the best,
