An UD02 can't be flashed to read UHDs. Sorry, buddy!KoLibre wrote: Tue Oct 06, 2026 12:28 pmHere is my Makemkv drive information (I have my drive now and this is what Makemkv reported when I connected it):Coopervid wrote: Sat Oct 03, 2026 4:21 pmC'mon! Get the drive and post its info. I will send the flasher then.KoLibre wrote: Sat Oct 03, 2026 4:04 pm
I do not have the drive yet, but all information except the serial number on the label matches with the one agent_x007 posted here about:
viewtopic.php?p=202739#p202739
I will check weather the firmware version on the drive is still old enough before I try flashing it, of course.
Does that help?
I guess it is okay to redact the serial number since the others are doing it too?Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-UD02D Revision: 1.02 Firmware date: 2014-02-10 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8410 Firmware version: ID84
Flashing Pioneer drives
Re: Flashing Pioneer drives
KoLibre
But LibreDrive can be enabled, so that it still works when inserting BluRay disks that have a newer AACS version, right? It says "Status: Possible, not yet enabled" in the LibreDrive Information, after all.Coopervid wrote: Tue Oct 06, 2026 3:42 pmAn UD02 can't be flashed to read UHDs. Sorry, buddy!KoLibre wrote: Tue Oct 06, 2026 12:28 pmHere is my Makemkv drive information (I have my drive now and this is what Makemkv reported when I connected it):Coopervid wrote: Sat Oct 03, 2026 4:21 pm
Regarding 4K, this is a newer hardware revision of the UD02D (HW:1.02, SW:1.02), the label says BDR-UD02TBD.
Forget about it. You made a bad purchase.
navirich
Hello Billycar11, I would like to request the BDRFlash tool. Here is the Makemkv info for my drive:
OS device name: E:
Product: BD-RW BDR-211M
Revision: 1.50
Serial number: xxxxxx
Firmware date: 2017-12-21
Highest AACS version: 82
Drive platform: Pioneer RS8801
Firmware version: ID58
Thanks in advance
OS device name: E:
Revision: 1.50
Thanks in advance
PM sent.navirich wrote: Wed Oct 07, 2026 5:19 pm Hello Coopervid, I would like to request the BDRFlash tool. Here is the Makemkv info for my drive:
OS device name: E:
Revision: 1.50
Thanks in advance
See below for emailnavirich wrote: Wed Oct 07, 2026 5:19 pm Hello, I would like to request the BDRFlash tool. Here is the Makemkv info for my drive:
OS device name: E:
Revision: 1.50
Thanks in advance
Send me your makemkv drive info section
For everyone else no need to post your drive info section here just reach out directly to avoid the long post approval process
navirich
My thanks to Coopervid and Billycar11 who both responded to my post.
I went with the automated flasher solution from Billy that is just one-click and does everything right first time.
Good bit of work Billy thanks again.
kraath
OS device name: J:
Product: BD-RW BDR-S08
Revision: 1.10
Serial number:
Firmware date: 2012-08-28
Highest AACS version: 76
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID43
OS device name: J:
Revision: 1.10
Serial number:
NOS Pioneer BDR-UD03 slim (crossflashed to BDR-UD04)
NOS Pioneer BDR-S08XLT fullsize (crossflashed to BD-RW BDR-S11JX)
NEW LG BU40N USB 3.2 (flashed and tested)
For sale worldwide!
mail to: aranynsales@proton.me for price quotes
For sale worldwide!
Yethidran
hi KoLibre, i wonder if you still have your UD02 with you? i have a UD02 also, but i didnt back up the original firmware before proceeding to crossflash it to a UD03 and then eventually to a UD04...now its a dead drive as the laserhead mechanism is stuck at the extreme opposite end instead of being positioned next to the central spindle where it should always be positioned to read discs..
if you still have your ud02, i would definitely be grateful if i could get the original ud02 firmware to bring back to live my dead ud02. thanks.
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlykraath wrote: Thu Oct 08, 2026 11:41 am Drive Information
OS device name: J:
Revision: 1.10
Serial number:
see below for email
Max_the_Claxx
Hi Billycar11, I would like to get the flasher tool for my ASUS SBW-06D2X-U (Pioneer RS8511 platform, pre 12/22 firmware from 2017). Unfortunately, I'm a new member and can't send PMs yet. Could you please send me a PM or reach out? Thanks a lot!
navirich wrote: Wed Oct 07, 2026 5:19 pm Hello Billycar11, I would like to request the BDRFlash tool. Here is the Makemkv info for my drive:
OS device name: E:
Revision: 1.50
Thanks in advance
See guide below just email with the exact subject line it says and you will receive a response within 5 minsMax_the_Claxx wrote: Thu Oct 15, 2026 7:30 pm Hi Billycar11, I would like to get the flasher tool for my ASUS SBW-06D2X-U (Pioneer RS8511 platform, pre 12/22 firmware from 2017). Unfortunately, I'm a new member and can't send PMs yet. Could you please send me a PM or reach out? Thanks a lot!
OS device name: E:
Revision: 1.50
Thanks in advance
