Is it possible to make this OEM burner (Pioneer DBR-209DBK) LibreDrive-compatible?
OS device name: F:
Manufacturer: FX
Product: FX-09A1-20231. H
Revision:
Serial number: ODDXXXXXXXXX
Bus encryption flags: 13
Highest AACS version: 77
Thanks for the help.
BDR-209DBK
Re: BDR-209DBK
That's not a drive info section for a 209Drake26 wrote: Tue Oct 06, 2026 8:35 am Hello,
OS device name: F:
Manufacturer: FX
Revision:
Check the drive drop down menu for it
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
