Flashing LG and Pioneer drives for UHD, incl. Pioneer firmware 12/2022+ (trev.bot)
Stavevan887
Re: Flashing Pioneer drives with firmware 12/2022+
Post by Stavevan887 » Thu Oct 01, 2026 8:55 am
:D Was able to flash my XD08 to XD08U with 12/27/2022 firmware. First I was having issue to flash the drive due to software issue. Once I sent the report to help email, I was able to get a response within 30 mins and got my drive to flash.
Definitely a champ!
skyrider
Post by skyrider » Thu Oct 01, 2026 7:11 pm
trev.bot 0.6.0-beta.74
Surveys on the Epson PP-100 (SXLT) drive can now read two small firmware samples with your consent, as a first step toward supporting it. The drive is identified only; no conversion is offered yet.
trev.bot 0.6.0-beta.73
Check and surveys now identify Pioneer-built drives sold under another name, such as the Epson PP-100 (SXLT) and ASUS BW-16D1X-U, so their platform details reach us for research. These drives are identified only; no conversion is offered for them yet.
Looking for a Pioneer 4K UHD drive?
Click here
trevbot
Post by trevbot » Fri Oct 02, 2026 6:29 am
zittrig wrote: Thu Oct 01, 2026 3:14 am Exciting!
Looking forward when the BDR-212EBK @ 1.05 will be flashable.
BDR-212EBK 1.05 support is now available in trev.bot 0.6.0-beta.78, with conversion to BDR-212U 1.05.
Update the app and run the free Check with that drive connected to confirm support for its exact firmware. Latest installer: trev.bot.
Let me know if Check does not offer the conversion.
I build trev.bot. LG & Pioneer drive flashing for Windows, macOS and Linux.
zittrig
Post by zittrig » Fri Oct 02, 2026 4:40 pm
trevbot wrote: Fri Oct 02, 2026 6:29 am
Success! Now both drives are not loneley hardware in the cupboard anymore and ready for action.
skyrider
Post by skyrider » Sun Oct 04, 2026 9:35 pm
trev.bot flash 0.6.0-beta.85 has been released today.
Changelog:
- Prepare is simpler: it checks the selected drive as part of preparation, so there's no need to run a separate Check first. Check is still available for free when you just want to see whether a drive is supported.
- Preparation advances automatically to the next required step. When a reconnect or power cycle is needed, it shows the status and the next action clearly. Starting the write still requires your confirmation and the hold-to-flash action.
- The final confirmation is clearer, serial entry handles case automatically to match the drive's serial, and the hold-to-flash confirmation works with the keyboard as well as the mouse.
- The flashing animation and progress display have been improved. Completion is clearer too: a completed flash says Flash complete, with any remaining readiness check explained separately and a reminder to test the drive.
- Updates now sits at the bottom of the navigation. It shows the latest release, with update actions at the top. Activated installations can check for and install an update when the app starts, as long as there isn't a pending flash session to finish.
- Appearance has its own page, making the app's visual options easier to find.
- A local flash history makes it easier to look back at completed operations. Activation code references are masked rather than showing the full code.
- Used flash licenses are displayed clearly. Entering a new valid activation code allows a previously completed drive to be flashed again.
- The review shows the target firmware version more clearly and uses the correct downgrade or crossflash label, including firmware-only changes.
- Firmware readback is faster. In the recent S12 verification, that part took about 17 seconds compared with about 47 seconds previously; timing will vary by drive and setup.
- The website screenshots have been refreshed to show the current app.
Download: https://trev.bot/v1/desktop-download
Screenshots: https://trev.bot/screenshots
Click here
skyrider
Post by skyrider » Mon Oct 05, 2026 9:07 pm
trev.bot flash 0.6.0-beta.86 has been released today.
The new firmware options are:
- Pioneer BDR-S11JX on firmware 1.53: conversion to BDR-211M 1.53.
- Epson EP2 / BDE-PR1EP PP100 on firmware 2.02: conversion to BDR-211M 1.53. Firmware 2.01 was already supported; this adds 2.02.
- Pioneer BDR-212D / 212DBK on firmware 1.02 or 1.03: BDR-212U 1.05 is available again as a target, alongside BDR-S12U 1.02. The app now lets you choose between the supported targets.
This release also improves firmware collection for BDR-S13JX 1.04. That is a collection improvement, not a new flashing route.
Preparation and firmware transfers are faster, and activation now explains verification failures while keeping the entered code available to retry.
Click here
austeros
Post by austeros » Tue Oct 06, 2026 12:10 pm
Worked with my 12/2022 BDR-XD08. Took ~ 5 minutes. Would recommend.
Barley
Post by Barley » Tue Oct 06, 2026 1:23 pm
skyrider wrote: Mon Oct 05, 2026 9:07 pm trev.bot flash 0.6.0-beta.86 has been released today.
Forgive my ignorance, but what would this specific firmware change accomplish? I have a Pioneer BDR-S11JX on firmware 1.53 that rips UHD's perfectly.
Thank you!
OneDay
Post by OneDay » Tue Oct 06, 2026 8:11 pm
Barley wrote: Tue Oct 06, 2026 1:23 pm
Thank you!
This updater enables drives that had no 4K support with a firmware date past 12/22. Before you could not cross flash because it was locked by pioneer if your firmware had a date of 12/22.
Post by Coopervid » Tue Oct 06, 2026 8:14 pm
OneDay wrote: Tue Oct 06, 2026 8:11 pm
Thank you!
The flash from S11JX to 211 is useless. That's his point.
trevbot
Post by trevbot » Wed Oct 07, 2026 6:16 am
Thanks for pointing that out. My script picked it up as a firmware match, and I should have checked whether there was any actual benefit before offering it. I’ve removed it from the site for purchase. I only want to offer downgrades and crossflashes that serve a purpose, like the recent downgrades needed for OWC enclosure compatibility.
Do you have a preferred target for the 212DBK? We currently support S12U 1.02 and 212U 1.05. Would S12JX or another target offer anything useful over those?
Post by Coopervid » Wed Oct 07, 2026 9:03 am
trevbot wrote: Wed Oct 07, 2026 6:16 am Thanks for pointing that out. My script picked it up as a firmware match, and I should have checked whether there was any actual benefit before offering it. I’ve removed it from the site for purchase. I only want to offer downgrades and crossflashes that serve a purpose, like the recent downgrades needed for OWC enclosure compatibility.
AFAIK Makemkv doesn't support the S12JX regarding Libredrive. Edit: Firmware 1.02 is not supported. Supported firmwares 1.0, 1.01, 1.03 and 1.05.
trevbot
Post by trevbot » Wed Oct 07, 2026 3:17 pm
Coopervid wrote: Wed Oct 07, 2026 9:03 am
Thanks for checking and clarifying which S12JX versions are supported. Appreciate the help!
Makar
Post by Makar » Wed Oct 07, 2026 9:17 pm
AFAIK, the only difference would be that S12JX offers the "CD Utility" function only available on that model and it's S13 counterpart.
trevbot
Post by trevbot » Tue Oct 13, 2026 9:23 pm
LG flashing is FREE right now — $0.00. No license required.
trev.bot 1.0.11 is out.
LG support. Cross platform. AutoFlash: check the drive, the app picks the firmware and flashes it. No more per-flash license. One license, three computers, all your devices. LG flashing is currently free during the introductory period.
Introductory price is $19.99 (regular price $29.99), LG and Pioneer flashing included. If you already bought a flash, your license has been upgraded automatically.
Also: OpenRipper, my free, open source auto-ripper. Put a disc in and it rips to your own storage, with a web dashboard to follow each drive. It uses MakeMKV to read discs, it's early days, and it doesn't need a flash license. github.com/redharp/openripper
https://trev.bot
PS: have a look at the appearance options in Settings. There's a retro Chrome look in there that I'm a bit too pleased with.
1.0.11 brings clearer flashing progress, a Check another drive button, and fixes for delayed check results and unnecessary repeat restarts.
Watch a real LG flash on my Mac.
