So, after a bunch of help from Billy, I run the MakeMKV thing on my Ghost in the Shell 4K UHD disc. It seemed to work fine, but seems to have created 3 slightly different sized copies of the same movie. They all seem to play, but I am sort of curious about why this might be happening. I ran it with the default 120 second skip criteria which I have now changed to be 30 seconds, but this little desktop box had a time with this one
Maybe you can see them here, but I haven't been having a lot of luck with getting screenshots to appear in these messages. (edit: Well, you can't see the screenshot. It created three 52.8 GB .mkv files. All seem to play fine, but they are all a few MB different in size.) I mean, I sure don't need 150gigs of this movie. Which is the best one to save and watch?
Thanks everyone
Super novice question
tcharp
tomty89
Re: Super novice question
You mean like it created three 52.8G MKV files out of one disc in a single rip? Or multiple rips with different versions of MakeMKV? Or multiple rips with the same version of MakeMKV?
P.S. Please upload your screenshot somewhere else and provide a link here. We can't see attachments.
What about the video length?but they are all a few MB different in size
Flesh
The version I kept was 1:26:23 in terms of duration, but that was regular Bluray, not 4k. I'm guessing one is the "Japanese" version, other is ENG, and third is... I don't something else that helps sync language a bit better.
Which to keep? Depends if you are a subs or dubs person. I bet if you scroll through the movies a bit you'd notice one has the opening/ending credits in English, the other in Japanese, maybe some signs are also changed up & translated.
tcharp
It created three approximately 52.8GB viewable MKV files on a single rip.
https://drive.google.com/file/d/1oIzsOy ... drive_link
According to this, the duration of all the files is the same as well as the bitrate.
Thank you
Thank you
Still can't see your screenshot.
Does one of the files have chapters and one of them not have chapters? You probably don't want the one without chapters.
Mr. Red
When you open the disc in MakeMKV you should see the three variants in the overview.
Open them and compare Audio Tracks, Subtitles and Chapters.
A disc can have different menus and playlists for different regions or specials, like Commentaries or Picture in Picture.
Sometimes the only difference is chapters: one has the chapter file included, while it's missing on the others.
Often they have different audio tracks. For example it's possible that one variant has additional audio commentary tracks, but is missing the chapters. Or one has the Asia related audio tracks, while the other the ones for the European countries. etc.
Last, compare the segment map of all variants.
With the seamless branching feature it's possible to add, re-order or replace segments of the movie to create different versions of the movie.
Often they only replace opening titles with the country specific name or add additional credits for the dubbing actors etc.
But this also allows to put different cuts (theatrical, extended, director's cut etc.) on the same disc.
If you are unsure, or want to have tracks from multiple variants you need to rip them all and combine them in MKVToolnix.
For such discs (especially UHD) always make a decrypted backup first. Then you can compare segments directly from the disc folder and re-rip movies to compare and test without stressing your disc drive.
ecathlonw
I ran into something very similar with one of my UHD discs. MakeMKV created several MKV files that were basically the same movie, with only a small difference in file size. I initially thought changing the minimum title length from the default 120 seconds would help, so I lowered the setting and tried ripping the disc again, but it did not really solve the issue.
