"Fake playlist" protection - help needed
Greg Staten
Re: "Fake playlist" protection - help needed
Beau Geste (1926) - Artcraft Pictures
Playlist: 00174.mpls
Segment List: 10101, 10100, 10111, 11110, 11011, 10010, 11101, 11000, 11001, 01011, 00001, 10110, 01000, 10001
Greg Staten
Flicker Alley: Laurel & Hardy Year 3 Three (Note: the playlists provided by Ashfall in late November must have been from a different mastering than the one that finally released at the end of the year as none of his titles turned out to be accurate for my copy. I also included all the supplements. These were found using Process Monitor.)
Disc 1:
Liberty (19:14) Playlist: 00072.mpls - Segment List: 01001, 10001, 01011
Wrong Again (20:49) Playlist: 00167.mpls - Segment List: 10100, 11101, 10000
That's My Wife (19:36) Playlist: 00055.mpls - Segment List: 11111, 10002, 11010
Big Business (20:05) Playlist: 00087.mpls - Segment List: 11019, 10110, 10114
Double Whoopee (19:46) Playlist: 00064.mpls - Segment List: 11000, 01010, 11002
Double Whoopee, 1970 Dubbed ver (18:25) Playlist: 00111.mpls - Segment List: 11001, 11016, 10111
Chuck McCann and Miles Kreuger on the dubbed ver (14:49) Playlist: 00124.mpls - Segment List: 17896, 10010
Laurel & Hardy: On Location in Year Three Playlist: 26292.m2ts - Segment List: 26292
Disc 2:
Bacon Grabbers (20:19) Playlist: 00101.mpls - Segment List: 13182, 64911, 9039
Angora Love (21:35) Playlist: 00067.mpls - Segment List: 34167, 12737, 21700
Unaccustomed As We Are (21:32) Playlist: 00044.mpls - Segment List: 73437, 75325, 87137
Unaccustomed As We Are, Silent ver (22:55) Playlist: - Segment List: 20111, 80009, 77281, 81140
Berth Marks (20:47) Playlist: 00078.mpls - Segment List: 73392, 03362, 27508
They Go Boom! (20:28) Playlist: 00055.mpls - Segment List: 21879, 33388, 63586
The Hoose-Gow (20:09) Playlist: 00102.mpls - Segment List: 57260, 95032, 60165
Hollywood Revue of 1929, Excerpt (8:12) Playlist: 22028.m2ts - Segment List: 20228
Noche de Duendes (Berth Marks), Excerpt (11:04) Playlist: 62960.m2ts - Segment List: 62960
1930 MGM Convention (2:28) Playlist: 71131.m2ts - Segment List: 71131
Disc 1:
Disc 2:
wilmcmillen
Hello! I just got the Flicker Alley Champagne & Caviar: Four Weimar Comedies set and I'm looking for the correct playlists. Can anyone help me out?
Garmon
Garden of Eden, Flicker Alley
For the Flicker Alley Garden of Eden disc. As an experiment, I uploaded the MovieObject.bdmv file to AI to see if it could find the correct playlist. It seems to have worked.
The answer is definitively 00043.mpls.
Here's what the MovieObject file reveals: the disc has 30 MovieObjects. MovieObject[0] (the First Play / initial dispatcher) scatters references across a wide variety of playlists — that's the obfuscation noise. But when you look at MovieObjects 13 through 29, which are the actual title entry points triggered by the disc's menu navigation, 15 out of 15 of them consistently call PlayPL to playlist 43 (0x2B). Every single menu-accessible title entry point leads to 00043.mpls, just at different chapter marks. That's an unambiguous signal — it's the real film.
The various chapter values (1, 2, 5, 6, 7, 9, 17, 31) represent scene selection entries in the disc menu, all pointing into the same playlist.
So in MakeMKV, select title 00043 and you'll have your rip.
RedMax12
Howard Hughes in Hollywood – Vol. 1
Disc 1: Two Arabian Knights
Source file name: 00076.mpls
Duration: 1:31:26
Segment map: 73922,5183,66239,50777,92500,64350,52596,21953,78063
File name: title_t118.mkv
The disc for The Racket does not use obscuration.
Duration: 1:31:26
ron@deentjes.nl
Kind of new here but: Is a fake list for example a disk that shows way more titles than actual episodes and they all appear the same?
Next question if yes: What is the meaning of "full backup¨? Are we talking using ¨dd"for example?
If so I can post "Occupied season 1¨
I just want to stream these titles on my own Plex network aaargh
Thanks in advance
Ron
Thanks in advance
Ron
I've never run across a TV show with fake playlists, but there certainly could be some. In the examples of movies I've come across, there are often more than 100 playlists that all seem to be the movie. However, all but one of them have some parts of the movie out of order. If a title is highlighted on the left the 'segment map' line on the right is an ordered lists of the segments that make up that title.ron@deentjes.nl wrote: Mon Sep 07, 2026 2:12 pm Is a fake list for example a disk that shows way more titles than actual episodes and they all appear the same?
On the first screen of MakeMKV there's an icon of a yellow folder with a green arrow. If you select this MakeMKV makes a full disc backup. This is usually what is meant when someone says a 'full backup'.ron@deentjes.nl wrote: Mon Sep 07, 2026 2:12 pm Next question if yes: What is the meaning of "full backup¨? Are we talking using ¨dd"for example?
ron@deentjes.nl
Thanks for the info, with Google I alread found that solution and I have uploaded some files to Dropbox to help out.dcoke22 wrote: Tue Sep 08, 2026 10:34 pmI've never run across a TV show with fake playlists, but there certainly could be some. In the examples of movies I've come across, there are often more than 100 playlists that all seem to be the movie. However, all but one of them have some parts of the movie out of order. If a title is highlighted on the left the 'segment map' line on the right is an ordered lists of the segments that make up that title.ron@deentjes.nl wrote: Mon Sep 07, 2026 2:12 pm Is a fake list for example a disk that shows way more titles than actual episodes and they all appear the same?
But this "Occupied" series really does contain these fake files for sure
Once again thanks,
Ron
ron@deentjes.nl
As a follow up: Willing to test if desired.
I run makemkv on Linux Mint and all my drives are "Libredrived"
Let me know how I can help
Regards
Ron
Regards
Ron
jfmac1991
I posted a question about ripping problems and my audiot did not rip? I saw the message and now it is gone?
I am guessing it was moved to the ripping problems message but don't know how to search for it?
Searching by username comes up with it.
https://forum.makemkv.com/forum/viewtopic.php?t=42552jfmac1991 wrote: Sun Oct 04, 2026 5:32 pm I posted a question about ripping problems and my audiot did not rip? I saw the message and now it is gone?
inxs77
Hello. This is my first post on the site.
I believe I have developed an extension for VLC that identifies the correct playlist every time no matter the disc backup you use it on.
All you gotta do is install the VLC extension I've developed and play the MAKEMKV Backup once via Media > Open Disc... > Blu-ray > PLAY.
All https://www.lua.org/docs.html based. All code visible. Nothing is compiled. No surprises.
I believe a proper post would be ideal but I am not certain I am allowed to post yet.
Please let me know if I can be allowed to post.
Thank you.
Thank you.
Justabackup
That would be great, especially if the code could be incorporated into MakeMKV directly to decode the obfuscation.
