Pioneer BDR-UD03 UHD possibility
Shish
Re: Pioneer BDR-UD03 UHD possibility
Post by Shish » Thu Oct 01, 2026 10:31 am
Hello, shot in the dark here as this was a pretty cheap external I bought for my blu rays but after it popped up that it had the BDR-UDO3 I figured I might as well see if it's UHD compatible. Thanks in advance!
OS device name: /dev/rdisk5
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.00
Serial number: MIDL006624WL
Firmware date: 2013-08-09
Highest AACS version: 23
Drive platform: RS8510
Firmware version: 1.00/ID19
Post by Coopervid » Thu Oct 01, 2026 7:18 pm
Shish wrote: Thu Oct 01, 2026 10:31 am Hello, shot in the dark here as this was a pretty cheap external I bought for my blu rays but after it popped up that it had the BDR-UDO3 I figured I might as well see if it's UHD compatible. Thanks in advance!
Revision: 1.00
PM sent.
Post by Billycar11 » Thu Oct 01, 2026 8:43 pm
Revision: 1.00
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
sakamdi
Post by sakamdi » Fri Oct 02, 2026 11:25 pm
Hey Coopervid - not sure if you'll see this but i'm stuck with this drive also if you could assist please?
Post by Coopervid » Sat Oct 03, 2026 10:00 am
sakamdi wrote: Fri Oct 02, 2026 11:25 pm Hey Coopervid - not sure if you'll see this but i'm stuck with this drive also if you could assist please?
You need to post your Makemkv info.
Tankistar
Post by Tankistar » Sat Oct 03, 2026 7:07 pm
Hi Coopervid, could you please check my drive for UHD flashing and PM me the tool/firmware? Thanks!
OS device name: E:
Revision: 1.14
Serial number: ALDL444777WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Post by Billycar11 » Sat Oct 03, 2026 10:00 pm
Tankistar wrote: Sat Oct 03, 2026 7:07 pm
OS device name: E:
Revision: 1.14
see below for email
Post by Coopervid » Sun Oct 04, 2026 9:57 am
Tankistar wrote: Sat Oct 03, 2026 7:07 pm Hi Coopervid, could you please check my drive for UHD flashing and PM me the tool/firmware? Thanks!
OS device name: E:
Revision: 1.14
PM sent.
sakamdi
Post by sakamdi » Sun Oct 04, 2026 3:11 pm
Coopervid wrote: Sat Oct 03, 2026 10:00 am
My bad - on it's face in makemkv:
OS device name: J:
Product: BD-RE BP55EB40
Revision: 1.00
Serial number: OBDL038140WL
Upon opening to inspect:
Pioneer BDR-UD03TBD
will this tool of yours help me to pair the actual disc drive to it's proper glory?
Post by Coopervid » Sun Oct 04, 2026 5:10 pm
sakamdi wrote: Sun Oct 04, 2026 3:11 pm
OS device name: J:
Revision: 1.00
Pioneer BDR-UD03TBD
Now what does Makemkv report? BP55EB40 -then it's an LG. But the sticker says UD03? Then the sticker is wrong and faked.
sakamdi
Post by sakamdi » Sun Oct 04, 2026 9:26 pm
Coopervid wrote: Sun Oct 04, 2026 5:10 pm
OS device name: J:
Revision: 1.00
Pioneer BDR-UD03TBD
Yeah, so the drive reports as BP55EB40, scammed on ebay but got refund. I'm figuring if I can flash it wth the BDR-UD03TBD firmware it should operate.
This isn't my area of expertise
Post by Coopervid » Sun Oct 04, 2026 10:25 pm
Sorry you are confused. This is a LG drive that can be flashed with a LG flasher, Pioneer drives require a completely different flasher.
sakamdi
Post by sakamdi » Sun Oct 04, 2026 10:37 pm
Coopervid wrote: Sun Oct 04, 2026 10:25 pm Sorry you are confused. This is a LG drive that can be flashed with a LG flasher, Pioneer drives require a completely different flasher.
Oh, as it was sold as LG, but contains a Pioneer, I hoped the pioneer firmware would solve.
Below is the drive within the bogus container
https://drive.google.com/file/d/1VrIDvm ... sp=sharing
Post by Coopervid » Sun Oct 04, 2026 10:53 pm
sakamdi wrote: Sun Oct 04, 2026 10:37 pm
Sorry buddy! The label doesn't count. What counts is what Makemkv is reporting.
sakamdi
Post by sakamdi » Mon Oct 05, 2026 9:16 pm
Coopervid wrote: Sun Oct 04, 2026 10:53 pm
Hi again Coopervid,
Thanks for your patience. I think there's an unusual edge case here that may explain the discrepancy.
This thread from last week appears to document essentially the same situation:
viewtopic.php?t=42497
That drive also reported to MakeMKV as HL-DT-ST BP55EB40 revision 1.00, and SDFTool reported MT1959 Platform: NO. After opening it, the mechanism was identified as a Pioneer BDR-UD03TBD HW/FW 1.00, and MartyMcNuts identified it as Pioneer/RS8511 hardware.
Mine likewise reports BP55EB40 1.00 in MakeMKV, SDFTool says MT1959 Platform: NO, but the physical mechanism is labelled Pioneer BDR-UD03TBD HW/FW 1.00.
So I'm reluctant to try LG firmware on it. Could this be the same unusual configuration as that other drive?
