PIONEER BDR-209 change the Firmware ?
karurosu15
Re: PIONEER BDR-209 change the Firmware ?
Post by karurosu15 » Sun Oct 04, 2026 9:26 am
I need the correct UHD firmware/patch for my Pioneer BDR-209D.
Información de unidad de disco
Nombre del SO del dispositivo: H:
Fabricante: PIONEER
Producto: BD-RW BDR-209D
Revisión: 1.51
Fecha del firmware: 2018-05-08
Marcas de cifrado bus: 13
Highest AACS version: 46
Drive platform: RS8601
Firmware version: 1.51/ID61
Could you please send me the correct firmware and flashing instructions for this drive?
Thank you.
Post by Coopervid » Mon Oct 05, 2026 12:02 pm
karurosu15 wrote: Sun Oct 04, 2026 9:26 am Hello,
Fabricante: PIONEER
Revisión: 1.51
Thank you.
PM sent.
Post by Billycar11 » Mon Oct 05, 2026 12:07 pm
Fabricante: PIONEER
Revisión: 1.51
Thank you.
See below for email
Send me your makemkv drive info section
For everyone else no need to post your drive info section here just reach out directly to avoid the long post approval process
somebodyshhh
Post by somebodyshhh » Wed Oct 07, 2026 4:28 pm
Hello, I have a BDR-209D with firmware 1.34. Does anyone have the flashing instructions and files?
Post by Billycar11 » Wed Oct 07, 2026 9:09 pm
somebodyshhh wrote: Wed Oct 07, 2026 4:28 pm Hello, I have a BDR-209D with firmware 1.34. Does anyone have the flashing instructions and files?
See below for email
Post by Coopervid » Thu Oct 08, 2026 10:25 am
Post your Makemkv info. There are 2 hardware versions and I need to know which one your has.
bchilds101
Post by bchilds101 » Sat Oct 17, 2026 6:31 am
OS device name: /dev/rdisk7
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: QKDL144780WL
Firmware date: 2015-10-20
Highest AACS version: 82
Drive platform: RS8600
Firmware version: E101/ID76
Post by Coopervid » Wed Oct 21, 2026 7:43 pm
bchilds101 wrote: Sat Oct 17, 2026 6:31 am Hello,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Linux or MacOS?
Post by Billycar11 » Wed Oct 21, 2026 9:57 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
No need to post your info just see guide below for all future posters
Sure just email me
With this exact subject line
Pioneer FW + Flasher Request
And you will receive the flasher and fw for free within 5 minutes
BDB33
Post by BDB33 » Sun Oct 25, 2026 8:47 am
Hi have read the guide and the first rule of flashing is "Make sure your Drive was built after 2016 on label or late 2015 if you want to risk it it says late 2015" Mine was built in Feb 2015, which by no means can be considered late. In a desperate plea that my drive isn't affected by this arbitrary cut-off, my details are below, should I try it?
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.30
Serial number: OBDL096894WL
Firmware date: 2014-12-05
Bus encryption flags: 13
Firmware version: 1.30/ID61
mattjackson86
Post by mattjackson86 » Fri Oct 30, 2026 11:14 pm
Your 209D can be cross flashed to expose UHD, just pick the firmware you want:
https://freemkv.org/firmware/find/?driv ... ision=1.51
