Pioneer BDR-UD03 UHD possibility
Shish
Re: Pioneer BDR-UD03 UHD possibility
Post by Shish »
Hello, shot in the dark here as this was a pretty cheap external I bought for my blu rays but after it popped up that it had the BDR-UDO3 I figured I might as well see if it's UHD compatible. Thanks in advance!
OS device name: /dev/rdisk5
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.00
Serial number: MIDL006624WL
Firmware date: 2013-08-09
Highest AACS version: 23
Drive platform: RS8510
Firmware version: 1.00/ID19
Shish wrote: Thu Oct 01, 2026 10:31 am Hello, shot in the dark here as this was a pretty cheap external I bought for my blu rays but after it popped up that it had the BDR-UDO3 I figured I might as well see if it's UHD compatible. Thanks in advance!
Revision: 1.00
PM sent.
Revision: 1.00
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
sakamdi
Post by sakamdi »
Hey Coopervid - not sure if you'll see this but i'm stuck with this drive also if you could assist please?
sakamdi wrote: Fri Oct 02, 2026 11:25 pm Hey Coopervid - not sure if you'll see this but i'm stuck with this drive also if you could assist please?
You need to post your Makemkv info.
Tankistar
Post by Tankistar »
Hi Coopervid, could you please check my drive for UHD flashing and PM me the tool/firmware? Thanks!
OS device name: E:
Revision: 1.14
Serial number: ALDL444777WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Tankistar wrote: Sat Oct 03, 2026 7:07 pm
OS device name: E:
Revision: 1.14
see below for email
Tankistar wrote: Sat Oct 03, 2026 7:07 pm Hi Coopervid, could you please check my drive for UHD flashing and PM me the tool/firmware? Thanks!
OS device name: E:
Revision: 1.14
PM sent.
sakamdi
Post by sakamdi »
Coopervid wrote: Sat Oct 03, 2026 10:00 am
My bad - on it's face in makemkv:
OS device name: J:
Product: BD-RE BP55EB40
Revision: 1.00
Serial number: OBDL038140WL
Upon opening to inspect:
Pioneer BDR-UD03TBD
will this tool of yours help me to pair the actual disc drive to it's proper glory?
sakamdi wrote: Sun Oct 04, 2026 3:11 pm
OS device name: J:
Revision: 1.00
Pioneer BDR-UD03TBD
Now what does Makemkv report? BP55EB40 -then it's an LG. But the sticker says UD03? Then the sticker is wrong and faked.
sakamdi
Post by sakamdi »
Coopervid wrote: Sun Oct 04, 2026 5:10 pm
OS device name: J:
Revision: 1.00
Pioneer BDR-UD03TBD
Yeah, so the drive reports as BP55EB40, scammed on ebay but got refund. I'm figuring if I can flash it wth the BDR-UD03TBD firmware it should operate.
This isn't my area of expertise
Sorry you are confused. This is a LG drive that can be flashed with a LG flasher, Pioneer drives require a completely different flasher.
sakamdi
Post by sakamdi »
Coopervid wrote: Sun Oct 04, 2026 10:25 pm Sorry you are confused. This is a LG drive that can be flashed with a LG flasher, Pioneer drives require a completely different flasher.
Oh, as it was sold as LG, but contains a Pioneer, I hoped the pioneer firmware would solve.
Below is the drive within the bogus container
https://drive.google.com/file/d/1VrIDvm ... sp=sharing
sakamdi wrote: Sun Oct 04, 2026 10:37 pm
Sorry buddy! The label doesn't count. What counts is what Makemkv is reporting.
sakamdi
Post by sakamdi »
Coopervid wrote: Sun Oct 04, 2026 10:53 pm
Hi again Coopervid,
Thanks for your patience. I think there's an unusual edge case here that may explain the discrepancy.
This thread from last week appears to document essentially the same situation:
viewtopic.php?t=42497
That drive also reported to MakeMKV as HL-DT-ST BP55EB40 revision 1.00, and SDFTool reported MT1959 Platform: NO. After opening it, the mechanism was identified as a Pioneer BDR-UD03TBD HW/FW 1.00, and MartyMcNuts identified it as Pioneer/RS8511 hardware.
Mine likewise reports BP55EB40 1.00 in MakeMKV, SDFTool says MT1959 Platform: NO, but the physical mechanism is labelled Pioneer BDR-UD03TBD HW/FW 1.00.
So I'm reluctant to try LG firmware on it. Could this be the same unusual configuration as that other drive?
