I would agree with you. However... fixing that would be the author's job. I would actually suggest dropping calling it "Expert mode" and making it the default (or just make Expert "on" when installed), but... I have to be careful, because I've had it turned on "forever", so I forget some things that do not appear with it off.I would argue that naming of the files is a basic feature, not an expert feature.
Changing names with Expert mode enabled
Re: Changing names with Expert mode enabled
CMDLineKing
Naming episodes can be easy. Sometimes it is a pain, but most of the time if you change the Top "Title" field, all the titles below will change to match that.
Example:
Friends Season 3 Disc 1
Change it to:
Friends - s03e
Now, when you hit enter, all the titles for the items below will be formatted in this way.
Title 1 : Friends - s03e
Title 2 : Friends - s03e
Title 3 : Friends - s03e
Title 4 : Friends - s03e
Now, you can click on the first video title - select the "Name" field and type in the remaining episode number - "01" to the end. DONT CLICK ANYTHING ELSE. Just hit the "down" arrow key. This will move you to the next title in the list. and you can add the "02" to the end. REPEAT till all episodes are named.
Will look like this after:
Title 1 : Friends - s03e01
Title 2 : Friends - s03e02
Title 3 : Friends - s03e03
Title 4 : Friends - s03e04
Start your rip! You can also open the disk in your DVD Player of choice to confirm which titles are which episodes. I have found certain companies don't always put them in order on the disc titles, so best to double check before or after.
Example:
Change it to:
Friends - s03e
LottieRoss
But can we change files to a foreign language, like renaming file with any japanese name?Dratikus wrote: Thu Jan 23, 2025 11:49 am I would argue that naming of the files is a basic feature, not an expert feature.
If you've enabled Expert mode, you can change the name of the output file to whatever you want, as long as it ends with ".mkv". You can actually change that, too, but it makes life afterward more difficult when the operation system uses the extension to enable features.
The "name" field can be edited without expert mode, if I recall, but the file name follows a number of different rules in that case. Expert mode makes life more predictable.
jimbo72
I use Chrome. I don't get the images. How do I do this? I don't know what to click on to get the image.
Woodstock wrote: Wed Jul 26, 2017 6:40 am have the browser display JUST the image, and it will allow that.
Chrome is also what I used, but... I cannot say how it has changed since they stopped supporting Win7. In Win7, I need only RIGHT-click on the "broken image" icon, and select "Open image in new tab", and it will display.
jimbo72
Oh! It worked! I'm on Win 11. Thanks for the reply!
x264encoder
@Woodstock I rehosted the images on Pixhost in case you want to replace them in the OP. Here they are (they are in the same order to make it easier):
Thank you!
[img]https://img3.pixhost.to/images/6116/777360469_openbackup1.png[/img]
[img]https://img3.pixhost.to/images/6116/777360470_titletrackselection.png[/img]
[img]https://pixhost.to/show/6116/777360471_changediskname.png[/img]
[img]https://img3.pixhost.to/images/6116/777360472_changetitlename.png[/img]
[img]https://img3.pixhost.to/images/6116/777360474_expertmodeproperties1.png[/img]
[img]https://img3.pixhost.to/images/6116/777360475_expertmodeproperties2.png[/img]
[img]https://img3.pixhost.to/images/6116/777360478_expertmodeproperties3.png[/img]
