Hello, shot in the dark here as this was a pretty cheap external I bought for my blu rays but after it popped up that it had the BDR-UDO3 I figured I might as well see if it's UHD compatible. Thanks in advance!
OS device name: /dev/rdisk5
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.00
Serial number: MIDL006624WL
Firmware date: 2013-08-09
Highest AACS version: 23
Drive platform: RS8510
Firmware version: 1.00/ID19
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM sent.Shish wrote: Thu Oct 01, 2026 10:31 am Hello, shot in the dark here as this was a pretty cheap external I bought for my blu rays but after it popped up that it had the BDR-UDO3 I figured I might as well see if it's UHD compatible. Thanks in advance!
Revision: 1.00
sure email me that info and all others email me no need to post your info here just reach out to me directlyShish wrote: Thu Oct 01, 2026 10:31 am Hello, shot in the dark here as this was a pretty cheap external I bought for my blu rays but after it popped up that it had the BDR-UDO3 I figured I might as well see if it's UHD compatible. Thanks in advance!
Revision: 1.00
see below for email
sakamdi
Hey Coopervid - not sure if you'll see this but i'm stuck with this drive also if you could assist please?
You need to post your Makemkv info.sakamdi wrote: Fri Oct 02, 2026 11:25 pm Hey Coopervid - not sure if you'll see this but i'm stuck with this drive also if you could assist please?
Tankistar
Hi Coopervid, could you please check my drive for UHD flashing and PM me the tool/firmware? Thanks!
OS device name: E:
Revision: 1.14
Serial number: ALDL444777WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Unrestricted read speed: Yes-
sure email me that info and all others email me no need to post your info here just reach out to me directlyTankistar wrote: Sat Oct 03, 2026 7:07 pmCode: Select all
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ALDL444777WL Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
see below for email
PM sent.Tankistar wrote: Sat Oct 03, 2026 7:07 pm Hi Coopervid, could you please check my drive for UHD flashing and PM me the tool/firmware? Thanks!
sakamdi
My bad - on it's face in makemkv:
OS device name: J:
Product: BD-RE BP55EB40
Revision: 1.00
Serial number: OBDL038140WL
Upon opening to inspect:
Pioneer BDR-UD03TBD
will this tool of yours help me to pair the actual disc drive to it's proper glory?
Now what does Makemkv report? BP55EB40 -then it's an LG. But the sticker says UD03? Then the sticker is wrong and faked.sakamdi wrote: Sun Oct 04, 2026 3:11 pm
OS device name: J:
Revision: 1.00
Pioneer BDR-UD03TBD
sakamdi
Yeah, so the drive reports as BP55EB40, scammed on ebay but got refund. I'm figuring if I can flash it wth the BDR-UD03TBD firmware it should operate.Coopervid wrote: Sun Oct 04, 2026 5:10 pmNow what does Makemkv report? BP55EB40 -then it's an LG. But the sticker says UD03? Then the sticker is wrong and faked.sakamdi wrote: Sun Oct 04, 2026 3:11 pm
OS device name: J:
Revision: 1.00
Pioneer BDR-UD03TBD
This isn't my area of expertise
Sorry you are confused. This is a LG drive that can be flashed with a LG flasher, Pioneer drives require a completely different flasher.
sakamdi
Oh, as it was sold as LG, but contains a Pioneer, I hoped the pioneer firmware would solve.Coopervid wrote: Sun Oct 04, 2026 10:25 pm Sorry you are confused. This is a LG drive that can be flashed with a LG flasher, Pioneer drives require a completely different flasher.
Below is the drive within the bogus container
https://drive.google.com/file/d/1VrIDvm ... sp=sharing
Sorry buddy! The label doesn't count. What counts is what Makemkv is reporting.sakamdi wrote: Sun Oct 04, 2026 10:37 pmOh, as it was sold as LG, but contains a Pioneer, I hoped the pioneer firmware would solve.Coopervid wrote: Sun Oct 04, 2026 10:25 pm Sorry you are confused. This is a LG drive that can be flashed with a LG flasher, Pioneer drives require a completely different flasher.
sakamdi
Hi again Coopervid,Coopervid wrote: Sun Oct 04, 2026 10:53 pmSorry buddy! The label doesn't count. What counts is what Makemkv is reporting.sakamdi wrote: Sun Oct 04, 2026 10:37 pmOh, as it was sold as LG, but contains a Pioneer, I hoped the pioneer firmware would solve.Coopervid wrote: Sun Oct 04, 2026 10:25 pm Sorry you are confused. This is a LG drive that can be flashed with a LG flasher, Pioneer drives require a completely different flasher.
Thanks for your patience. I think there's an unusual edge case here that may explain the discrepancy.
This thread from last week appears to document essentially the same situation:
viewtopic.php?t=42497
That drive also reported to MakeMKV as HL-DT-ST BP55EB40 revision 1.00, and SDFTool reported MT1959 Platform: NO. After opening it, the mechanism was identified as a Pioneer BDR-UD03TBD HW/FW 1.00, and MartyMcNuts identified it as Pioneer/RS8511 hardware.
Mine likewise reports BP55EB40 1.00 in MakeMKV, SDFTool says MT1959 Platform: NO, but the physical mechanism is labelled Pioneer BDR-UD03TBD HW/FW 1.00.
So I'm reluctant to try LG firmware on it. Could this be the same unusual configuration as that other drive?
