Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
vdbnt wrote: Sat Sep 19, 2026 6:06 pm Hi there,
I would like to make my PIONEER BDR-US03 UHD capable. Could you please provide the correct flash kit for my drive?
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Firmware date: 2018-08-22
Drive platform: RS8511
Firmware version: E101/ID26
Many thanks in advance!
PM sent.
Manufacturer: ASUS
Revision: E101
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
darkslayer3655
Post by darkslayer3655 »
Hi, had a quick question. New to this but found a Pioneer BDR-XD07 Blu-Ray dr with the 1.02 original firmware. Am i correct in assuming it can support UHD as well even though it doesn't specify it like in yalls list? or is it able to be flashed over to also support UHD since it is in that series? Thanks!
mrmonk
Post by mrmonk »
Is @billycar11 still selling drives? Emailed him and no response
darkslayer3655 wrote: Tue Sep 22, 2026 2:14 am Hi, had a quick question. New to this but found a Pioneer BDR-XD07 Blu-Ray dr with the 1.02 original firmware. Am i correct in assuming it can support UHD as well even though it doesn't specify it like in yalls list? or is it able to be flashed over to also support UHD since it is in that series? Thanks!
Yes. Post your Makemkv info.
see below for email
Bumbuliuz
Post by Bumbuliuz »
Sorry if this has been answered before.
I have this Verbatim BD drive, am I correct in it can't be flashed to rip 4K discs?
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 82
Firmware version: 1.14
Bumbuliuz wrote: Wed Sep 23, 2026 2:33 am Sorry if this has been answered before.
OS device name: J:
Revision: 1.14
Yes, it can be flashed. Email Billycar11 (in his signature, 2 posts prior to this one) as he has a flasher for that.
OS device name: J:
Revision: 1.14
see below for email
Thanks Marty
mrbarbie
Post by mrbarbie »
I recently purchased the BP60NB10 (SVC: NB12) model.
I wanted to back up the original OEM firmware before flashing it with the "DE_LG_BP60NB10-NB12_1.02-MK.bin" firmware for UHD ripping. However, I realized I needed the original .bin file, and I found that the old download links on the forum are no longer working.
Would it be possible to obtain the "HL-DT-ST-BD-RE_BP60NB10-NB12-1.02-N000300-212107081556.bin" firmware file?
Thank you in advance!
Mairi
Post by Mairi »
So I seem to have myself in a bit of a pickle here trying to read xbox 360 discs ...
I started with an LG WP50NB40, SVC code NB52.
after first flashing it to completely the wrong firmware (redumper won't recognise it) as a BP60NB10, I eventually got the drive to identify as a BU40N rev 1.03, MK firmware.
I then write it to the 1.00 firmware. Drive is now recognised by Redumper but fails to get the .Security file ... which would tend to indicate the firmware is wrong, but Redumper says the firmware is FINE but the drive won't work. Not sure what to do next ... Ugh. I have been at this for HOURS.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f -l
Found 2 drives(s)
00: \Device\CdRom0, \Device\CdRom0, E:
TSSTcorp_CDDVDW_SE-208DB_MF00_R8X76YAF202838
01: \Device\CdRom1, \Device\CdRom1, F:
HL-DT-ST_BD-RE_BU40N_1.00_211612201528_SIM21M3MH1706
suggestions as to what to try next?
Sayaka
Post by Sayaka »
Mairi wrote: Mon Sep 28, 2026 9:00 pm Hi,
Found 2 drives(s)
You need to flash this : https://archive.org/download/OmniDrive_ ... -1.0.4.bin
Use RECOVER (OR rawflash boot with "MT1959 Boot BU5 " as the boot code, keep the space before the second quote), OR even rawflash full of your current firmware and then rawflash main of OmniDrive, just in case; because I cannot guarantee that this will work if you do a regular WRITE (rawflash main).
EDIT : Also, please be aware that by default redumper will likely try to use the TSSTcorp drive. You might need to force it to use the WP50NB40 using
redumper --drive=F
or
redumper --drive=F:
Tsunamijhoe
Post by Tsunamijhoe »
Hey guys.
I just got a Verbatim 43888 as i was told this could rip 4k right out of the box, it cannot!
Can i make it able to rip 4k? If so, how do i go about it? I did read the first post here,but i am confused how to actually go about flashing it with the correct firmware?
This is what MakeMKV says is the drive:
Product: BD-RE BU40N
Revision: 1.05
Serial number: *************
Thank you for your help
Tsunamijhoe wrote: Wed Sep 30, 2026 2:18 pm Hey guys.
Revision: 1.05
Serial number: apples
yes it can be flashed to do uhd see post 1
or reach out to me or marty for an automated flasher
see profile for email
Tsunamijhoe
Billycar11 wrote: Wed Sep 30, 2026 2:41 pm
Revision: 1.05
OK, i did a hail mary, and yolo sdftool flasher to 1.03 and it seems to be working.. Lucky me :-)
