Hello!
I'm experiencing a problem I haven't encountered before, with a new King Crimson "Islands" Atmos Blu-ray disc.
While the disc (in a Buffalo drive) is physically connected to my Windows laptop, MakeMKV (2.0.0) is able to scan the disk, present all titles, and rip the titles to Matroska container files just fine.
However, when I use the Backup function to remove encryption and create a folder of the BD folder/file structure, MakeMKV is unable to open those files. When I point it at the index.bdmv file, it starts scanning the source and then stops responding, erroring to a "Fatal error occurred, program will now exit" popup. There is no useful information in the debug log file, just this:
003006:0000 Opening files on harddrive at file://C:/Users/tommy/Downloads/backup/KING_CRIMSON_ISLANDS
DISCID=36203454BFFA7B12F804B5FF9063520E0F9F8771
The backup of the BD completed without errors, and I've even tried two different BD drives and two different computers, all resulting in the same outcome.
I've even used DVDFab to both create a clone ISO, and file structure copy, and MakeMKV chokes on both of those in the exact same way. I also tried opening the file structure from the macOS version of MakeMKV on a Mac Mini, and it errors in the same way.
If MakeMKV can open the encrypted structure from the physical disk and process rips, but then can't do the same with the unencrypted structure...that makes no sense to me.
Any ideas on this weirdness?
MakeMKV fatal error when opening a BD backup it created
jharle
jharle
Re: MakeMKV fatal error when opening a BD backup it created
Oh my, I just read the previous post talking about the same thing. The suggestion of downgrading MakeMKV to 1.18.4 worked!
I guess it's a bug in the 2.0.0 version then.
Problem solved!
Problem solved!
Annihilation
Same here, there appears to be a bug in the v2.0.0. I hope mike takes note.
jharle
Indeed I've created several more backups of BDs since having the problem with 2.0.0, and it continues to be a problem for me. I've tried 2.0.0 on other computers as well (and different operating systems), and experience the same on those. I must be unlucky, as it feels like "not many" people are running into this, otherwise it would have been fixed by now.
On my Windows laptop, I periodically use winget to upgrade packages via PowerShell, and that always reinstalls MakeMKV 2.0.0. I know I could "pin" the older version, but haven't bothered to do that; I keep naively thinking that a 2.0.1 will drop which fixes the problem.
Hardly anyone is using v2.0.0 as it has lots of issues.jharle wrote: Tue Nov 03, 2026 6:10 am Indeed I've created several more backups of BDs since having the problem with 2.0.0, and it continues to be a problem for me. I've tried 2.0.0 on other computers as well (and different operating systems), and experience the same on those. I must be unlucky, as it feels like "not many" people are running into this, otherwise it would have been fixed by now.
gwhitcombe71
yeah, that matches what I've seen Marty... winget bumped me to 2.0.0 as well and I didnt realise until a backup wouldnt open (lost an evening swearing at it, definately not my finest). To be fair pinning is dead easy, just `winget pin add` with the package id and it leaves MakeMKV alone while everything else still updates. Ive stuck on 1.18.4 since and its been proper good, so jharle might as well pin it rather than wait for a 2.0.1 (bit like waiting on a Defender part to turn up, could be a while).MartyMcNuts wrote:Hardly anyone is using v2.0.0 as it has lots of issues.
jharle
Indeed although instead of pinning it, I just edited the registry to change the display version to 2.0.0, so that when an update does get released, winget will see it.gwhitcombe71 wrote: Wed Nov 04, 2026 1:05 pm...jharle might as well pin it rather than wait for a 2.0.1 (bit like waiting on a Defender part to turn up, could be a while).
gwhitcombe71
ha, editing the registry display version is a proper clever workaround actually, didnt think of that one... bit like how ive hacked the MOT reminder sticker on the Defender before nowjharle wrote:Indeed although instead of pinning it, I just edited the registry to change the display version to 2.0.0, so that when an update does get released, winget will see it.
