On-the-fly conversion to FLAC supports 24-bit data?
paulster
Post by paulster » Thu Apr 05, 2012 12:40 am
Now that MakeMKV supports on-the-fly conversion to FLAC format, amongst others, does it retain the full 24-bit resolution from a 24-bit LPCM source? From what I've read before FFmpeg is limited to 16-bit audio, although it's not a tool I generally use so I could well be wrong.
ryanjk333
Re: On-the-fly conversion to FLAC supports 24-bit data?
Post by ryanjk333 » Thu Apr 05, 2012 3:02 am
Unfortunately just 16 bit for now, because of the ffmpeg limitation, as you stated. The creator of MakeMKV confirms this at the bottom of his post here:
http://www.makemkv.com/forum2/viewtopic.php?f=10&t=4776#p19577
But is sounds like its just a temporary limitation, so hopefully soon we will get 24 bit support when this issue is fixed in ffmpeg.
MakeMKV registered!
LG External 12x Super Multi Blue Lightscribe Blu-Ray Rewriter BE12LU30
Popcorn Hour C-200
paulster
Post by paulster » Thu Apr 05, 2012 5:43 am
D'oh! How did I miss that before?!
Thanks for setting me straight.
ryanjk333
Post by ryanjk333 » Fri May 18, 2012 2:48 am
Well, since spam bumped this post back to the top, now might be a good time for me to ask:
Does anyone know when 24-bit flac support will be coming to MakeMKV? I understand that depends entirely on ffmpeg, but are there any estimated release dates anyone knows of for 24-bit flac support there?
MakeMKV registered!
Popcorn Hour C-200
crowfax
Post by crowfax » Fri May 18, 2012 4:01 am
ryanjk333 wrote:I understand that depends entirely on ffmpeg
Then you should probably ask the ffmpeg developers:
http://ffmpeg.org/contact.html
