Flashing Pioneer drives
most of the regular forum visitors might know me. New members might not.
LG / ASUS / Buffalo drive can be flashed by tools available free in this forum. Pioneer drives can't since the tool, even freeware, is not publicly available. For reasons I will not elaborate here.There are two members in this forum who can provide the tool. One of them is me. I don't charge for it. I only ask for a (small) donation after sending. Now this tool - BDRFlash- is Freeware but only works for pre 12/22 firmware. The other person who provides pre 12/22 firmware has an autoflasher that uses BDRFlash in the background and charges $40. Some time ago $20 what was still Ok. This person also has a monopoly solution until recently to flash post 12/22 drives and charges $200 for that service that always bothered me.
There's a new guy in town. Trevor. He invited me to test his new flasher for post 12/22 drives for free. He charges usually $29.99 per drive. So I decided to bite the bullet. I have a 212DBK drive that I flashed to S12U 1.02 for reading UHDs. The drive worked and works perfectly. My thought: I flash it to S12U 1.05 with the official flasher. It will still be supported by Mike's November 2025 update and still be Libredrive compatible and read UHDs. So if a flash goes wrong and the drive isn't bricked I will still be OK. The only risk was that Trevor's flasher might brick the drive.
I flashed to S12U 1.05 with the official Pioneer flasher and then tried Trevor's flasher. To make a long story short: It was successfully flashed back to pre 12/22 1.02 firmware!!!
The flashing process takes about 6 min.
Trevor's flasher is hereby recommended and a bargain compared to what was available until now.
Here's a link to his site:
https://research.trev.bot
And some more experiences with his tool:
viewtopic.php?t=42445
zittrig
Re: Flashing Pioneer drives
Post by zittrig »
Yes, first positive experience here too.
12/22+ pioneer flashing is now free for personal use
all you have to do is email me
it will be added to official guide soon
Coopervid wrote: Tue Sep 29, 2026 5:31 pm Hi,
The flashing process takes approx. 6 min.
The flashing process take approx. 6 min
KoLibre
Post by KoLibre »
Hello Coopervid, I would like to request the BDRFlash tool, if you don't charge for it as you wrote. Thanks!
KoLibre wrote: Sat Oct 03, 2026 12:01 am Hello Coopervid, I would like to request the BDRFlash tool, if you don't charge for it as you wrote. Thanks!
You need to post your Makemkv info for your drive.
KoLibre
Post by KoLibre »
Coopervid wrote: Sat Oct 03, 2026 9:59 am
I do not have the drive yet, but all information except the serial number on the label matches with the one agent_x007 posted here about:
viewtopic.php?p=202739#p202739
I will check weather the firmware version on the drive is still old enough before I try flashing it, of course.
Does that help?
KoLibre wrote: Sat Oct 03, 2026 4:04 pm
Does that help?
C'mon! Get the drive and post its info. I will send the flasher then.
topcat
Post by topcat »
Hello, this is my drive information. not sure if it matters but it is an external drive over USB! wondering if it can be flashed for 4k discs!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Firmware date: 2020-07-21
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: E116/ID71
topcat wrote: Sat Oct 03, 2026 5:08 pm Hello, this is my drive information. not sure if it matters but it is an external drive over USB! wondering if it can be flashed for 4k discs!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
PM sent.
XdarknidjaX
Post by XdarknidjaX »
Hello Coopervid,
I have a spare Pioneer drive, is it possible to flash this for 4k?
Drive informatie
Naam OS-apparaat: F:
Fabrikant: PIONEER
Product: BD-RW BDR-208D
Revisie: 1.50
Firmware datum: 2015-09-24
Bus encryptie flags: 13
Highest AACS version: 64
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.50/ID61
XdarknidjaX wrote: Sun Oct 04, 2026 1:20 pm Hello Coopervid,
Drive informatie
Fabrikant: PIONEER
Revisie: 1.50
PM sent.
KoLibre
Post by KoLibre »
Coopervid wrote: Sat Oct 03, 2026 4:21 pm
Does that help?
Here is my Makemkv drive information (I have my drive now and this is what Makemkv reported when I connected it):
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-UD02D
Revision: 1.02
Firmware date: 2014-02-10
Drive platform: Pioneer RS8410
Firmware version: ID84
I guess it is okay to redact the serial number since the others are doing it too?
