MakeMKV fatal error when opening WineCountryFlix non-commercial discs
rumokeenme
Post by rumokeenme »
Hey folks. Please forgive & redirect me if I'm posting in the wrong place here.
I've only recently gotten a Blu-ray drive and started buying DVDs and [non-4k] discs for our collection. So far, MakeMKV has worked beautifully for all the commercial discs I've tried. While looking for certain shows (like Disney's Amphibia), I realized that no DVD or Blu-ray releases were ever made for a bunch of the things we wanted, but I found a particular seller on poshmark (https://poshmark.com/closet/winecountryflix) that sells discs that apparently have been ripped from online streaming services. I took a chance on one and... once I received the Amphibia Complete Series (awesome show) from them, I found it played perfectly in my set-top player. Honestly, I was shocked and pleasantly surprised -- the interactive menu was one of the best I've ever seen (letting you view eight 60s episode thumbnails at a time, among other cool things) and I couldn't find any fault in the video quality (compared to the same on Disney+, which I also have). After that, I bought 2 more discs from the same seller.
All that said... opening theses discs in MakeMKV is another story. First thing: they play in VLC, so that's nice. Aside from that, the first thing I notice: the label on the discs is always "Aladdin (1994)". Weird.
I can successfully use File/Backup if I uncheck the "Decrypt video files" option (leaving that checked causes a crash). I can then find the 3 or so giant files and encode them, but I'd have to manually split the dozens of episodes out by hand. Moving on from the backup... if I try to open one of these discs in the usual way so that MakeMKV can parse the playlists and present titles to me for ripping, it always crashes with "Fatal error occurred" right after saying:
AACS directory not present, assuming unencrypted disc
Enabling debugging doesn't give any details in the log, so that's a bummer. Does anyone have suggestions or insight you could share?
Re: MakeMKV fatal error when opening WineCountryFlix non-commercial discs
What happens if you open the backup you created with MakeMKV?
rumokeenme
dcoke22 wrote: Tue Sep 29, 2026 3:31 pm What happens if you open the backup you created with MakeMKV?
Yeah this was the first thing I thought of, but I don't see any way to open a backup as a dir. Of course, I've tried opening every individual file (from the backup folder) that MakeMKV's Open Files dialog lets me see and they all just make it crash. Based on size, the actual videos are in .m2ts files, but those don't show up in the Open Files dialog. (I can open them in Handbrake, but as I implied in my first post, they're hours long so it would be a lot of work to manually split them out into separate episodes.)
PS: Thanks for reading and responding!
rumokeenme
For clarity: I could open the backup dir (or even the original disc) in Handbrake, as it does split the giant multi-hour files by chapters that correspond to episode starts; however, since these discs are likely already transcoded once, I'd prefer to split them with LosslessCut which doesn't support auto-splitting .m2ts via .mpls but would support splitting an mkv with chapters (like MakeMKV would make if I could get it to work right with these discs).
Opening a backup in MakeMKV varies a little bit depending on your platform. If you're on a Mac, in the folder you created the backup into you'll typically see an item called BDMV. On Windows (and probably Linux too) BDMV will be a folder and insider there will be a file called Index.bdmv or MovieObject.bdmv. Choose one of those and MakeMKV open the backup just as if it was opening the disc.
On a different subject, the thread Splitting apart episodes gives a decent overview of how to use MKVToolNix to split a big .mkv file at chapter boundaries. So, if you can get .mkv files of those big, multi-episode files and assuming the breaks between episodes are at a chapter marker, it shouldn't be too hard to get individual episodes.
As for MakeMKV crashing, others on the forum have been reporting some crashes with the latest 2.0.0 version. You could try going back to the previous version 1.18.4 (https://makemkv.com/download/old/) to see if that helps.
rumokeenme
dcoke22 wrote: Wed Sep 30, 2026 4:37 am Opening a backup in MakeMKV varies a little bit depending on your platform. If you're on a Mac, in the folder you created the backup into you'll typically see an item called BDMV. On Windows (and probably Linux too) BDMV will be a folder and insider there will be a file called Index.bdmv or MovieObject.bdmv. Choose one of those and MakeMKV open the backup just as if it was opening the disc.
Gotcha. Good to know that's the way it's supposed to work. (It crashes when I do that.)
dcoke22 wrote: Wed Sep 30, 2026 4:37 am On a different subject, the thread Splitting apart episodes gives a decent overview of how to use MKVToolNix to split a big .mkv file at chapter boundaries. So, if you can get .mkv files of those big, multi-episode files and assuming the breaks between episodes are at a chapter marker, it shouldn't be too hard to get individual episodes.
I'll try out an old version.
Thanks for your time and suggestions!
rumokeenme
I tried to build v1.18.4 on my Fedora system from the requisite tarball on the old releases page, but in the end I ran into package conflicts and gave up.
After looking at reddit, I came across https://github.com/chad3814/zenvik which was exactly what I needed for these discs that don't have encryption. It worked perfectly to create mkv files that I could finally split easily with mkvtoolnix.
Matin
Post by Matin »
I'm having the same problem with a star trek continues .iso, MakeMkv 2.0.0. I get a faial error occurred popup right after “AACS directory not present, assuming unencrypted disc”
rumokeenme
Try zenvik. I successfully used it for multiple discs.
