New to ripping, MakeMKV not opening discs
craaaig93
#1 Post by craaaig93 » Sun Sep 27, 2026 6:27 pm
I am new to the world of MakeMKV and ripping my 4K Blu-rays and I am having some trouble. I have purchased a disc drive that is a Pioneer BD-RW BDR-UD04.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.11
Serial number: TEDL218891WL
Highest AACS version: 61
I believe this is capable of ripping 4K straight from the box. When I launch MKV, it is showing the movie I have inserted and the information but when I click on the tile to open the disc, it fails every time with these messages appearing over and over
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0
I have searched online to try and fix but have had no luck so far. I have downloaded the SDF.bin file and keydb.cfg file to no success. The drive comes with a Y-split cable, dual split Micro-B USB 3.0 one end and then USB-C and USB-A. I have tried multiple ports on my PC and no luck. Getting quite frustrated as I was really excited to get started with ripping my movies and thought it was kind of plug and play.
Any help is greatly appreciated, thank you
Re: New to ripping, MakeMKV not opening discs
#2 Post by MartyMcNuts » Sun Sep 27, 2026 11:00 pm
craaaig93 wrote: Sun Sep 27, 2026 6:27 pm Hi,
OS device name: F:
Revision: 1.11
In MakeMKV's Libredrive info section does it say LibreDrive enabled?
