ASUS BW‑16D1HT 3.10 — MK firmware confirmation
LatencyGhost
Post by LatencyGhost » Sun Sep 27, 2026 7:32 am
I have questions regarding my ASUS BW‑16D1HT drives which I purchased from eBay. Straight out of the box LibreDrive Information displays
Firmware version: 3.10
I flashed 3.10MK using SDFTool Flasher. The tool reports “Flash completed” but the read out is the same as above. Is the drive currently 3.10MK even though MKV does not specifically say Firmware Version: 3.10"MK"? Secondly, for my other drive can I directly flash 3.02MK or does the drive require flashing 3.10MK before flashing 3.02MK? If you could clarify that would be great.
Kind Regards.
Re: ASUS BW‑16D1HT 3.10 — MK firmware confirmation
Post by Billycar11 » Sun Sep 27, 2026 9:25 pm
LatencyGhost wrote: Sun Sep 27, 2026 7:32 am Hi,
Kind Regards.
Your fine does it work?
LatencyGhost
Post by LatencyGhost » Sun Sep 27, 2026 10:37 pm
Hi, thank you for your urgent reply. I don't have any 4K UHD discs to test but I purchased the drive to be able to archive media etc including 4K UHD content. Is the drive currently firmware 3.10MK even though MKV does not specifically show the "MK" in the firmware version and can I directly flash 3.02MK or is it a requirement to flash 3.10MK first. Regards.
Post by Billycar11 » Sun Sep 27, 2026 10:49 pm
LatencyGhost wrote: Sun Sep 27, 2026 10:37 pm Hi, thank you for your urgent reply. I don't have any 4K UHD discs to test but I purchased the drive to be able to archive media etc including 4K UHD content. Is the drive currently firmware 3.10MK even though MKV does not specifically show the "MK" in the firmware version and can I directly flash 3.02MK or is it a requirement to flash 3.10MK first. Regards.
3.10mk works fine
It won't show me in the info it will just say libredrive enabled and microcode access re enabled
LatencyGhost
Post by LatencyGhost » Sun Sep 27, 2026 10:58 pm
Thanks. I have seperate drives, does 3.02MK have better error correction, I plan to have a drive with 3.10MK and the other drive with 3.02MK, please confirm 3.10MK is faster but 3.02MK is better for more problematic discs?
Regards.
LatencyGhost
Post by LatencyGhost » Mon Sep 28, 2026 7:41 am
Sorry for bombarding you with so many questions but I can't afford to brick my drive, I'll keep it brief. I have the All You Need Firmware Pack (Marty McNuts), and the 3.02 bin does not specify MK either, is it a safe downgrade to flash? Thank you for your input thus far and I hope to hear from you soon. Regards.
Post by MartyMcNuts » Mon Sep 28, 2026 7:56 am
LatencyGhost wrote: Sun Sep 27, 2026 10:58 pm Thanks. I have seperate drives, does 3.02MK have better error correction, I plan to have a drive with 3.10MK and the other drive with 3.02MK, please confirm 3.10MK is faster but 3.02MK is better for more problematic discs?
Regards.
There is no such thing as 3.02-MK, only the original 3.02.
Don't think it is any better.
LatencyGhost
Post by LatencyGhost » Mon Sep 28, 2026 8:15 am
Thank you Marty, I have a far better understanding now and I appreciate your time. Kind Regards.
