Blu-ray disc failure to open
Audidude
Post by Audidude »
Sopranos Season 6 Part 1 Disc 3 failed to open - following dump:
Evaluation version, 18 day(s) out of 30 remaining
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?b29AEbQSCNVPve...
The AACS dump file "/Users/gregsmbp16/Library/MakeMKV/MKB_v46_The_Sopranos_Season_6_Part_1_Disc_3_DF7A.tgz" was successfully sent for analysis
Same issue for Disc 4.
Reporting as requested - newbie here - is this what I'm supposed to do?
Sayaka
Re: Blu-ray disc failure to open
Post by Sayaka »
Not really, and I will explain more later, but for now :
Could you please download this :
https://fvonline-db.bplaced.net/fv_down ... p?lang=eng
Extract it, rename the file to KEYDB.cfg (capital letters matter !) and copy & paste it inside the MakeMKV config folder (you seem to be on a Mac, so it should be some kind of hidden ".MakeMKV" folder inside your home folder, I would assume - it could also be that "/Users/gregsmbp16/Library/MakeMKV/" folder). Can you please tell me if that solves your issue ?
Also, make sure you are using version 1.18.4, please : https://makemkv.com/download/old/
Audidude
Post by Audidude »
Using the version you said, placed the KEYDB.cfg file in the hidden library folder for MakeMkv and yes it worked!!
Thank you so much :)
Sayaka
Post by Sayaka »
You're welcome ! :)
This file gets updated frequently, so if you ever stumble upon another disc that doesn't work, it might be worth re-downloading it and re-placing it inside the correct folder.
To clarify : There is generally no need to make a post inside the "Blu-ray discs" subforum and post your log there if MakeMKV cannot decrypt a Blu-ray disc.
On the other hand, if you ever have an issue where a regular Blu-ray disc does not open even after using the latest version of KEYDB.cfg, it is worth checking out this thread : viewtopic.php?t=38293
The same is true if you have LibreDrive and you have an issue with a UHD disc. In that case though, you should also send the full AACS dump (the tgz file for that disc) to svq@makemkv.com
(I know you didn't ask, but just in case there is currently no need to send AACS dumps of regular Blu-ray discs to svq@makemkv.com)
