Asus BW-16D1X-U
Re: Asus BW-16D1X-U
#16 Post by Billycar11 » Fri Sep 25, 2026 3:33 am
funkywaddle wrote: Fri Sep 25, 2026 3:10 am
enc, not main?
I did finally get it to work. I had to downgrade to 1.17.7. It seemed to work alright. I'm currently making a mkv from a bluray disc. We'll see if it works.
Should I have done enc instead of main? Do I need to do it again?
yes had to be enc
movieman12345
Re: Asus BW-16D1X-U
#17 Post by movieman12345 » Fri Oct 09, 2026 5:37 pm
Just found this drive, will it be able to do 4kUHD out of the box? Can I flash it if not? I have seen conflicting reports online
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: QKDL141900WL
Firmware date: 2017-01-15
Highest AACS version: 81
Drive platform: RS8600
Firmware version: E102/ID76
OneDay
Re: Asus BW-16D1X-U
#18 Post by OneDay » Sat Oct 10, 2026 6:21 pm
movieman12345 wrote: Fri Oct 09, 2026 5:37 pm Just found this drive, will it be able to do 4kUHD out of the box? Can I flash it if not? I have seen conflicting reports online
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
You will need to cross flash it to Pioneer BDR-S11.
Re: Asus BW-16D1X-U
#19 Post by Billycar11 » Sat Oct 10, 2026 6:56 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
See guide below
Re: Asus BW-16D1X-U
#20 Post by Coopervid » Sat Oct 10, 2026 7:37 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Are you on Linux ARM or x64? I need to know to send the appropriate flasher.
