MakeMKV new version v2.0.0 (20.9.2026)
Ferrett1983
#1 Post by Ferrett1983 » Tue Sep 22, 2026 12:23 pm
I seem to be having a problem opening a blu-ray disc up on this version. It tries to open disc but then hangs/crashes.
cdheer
Re: MakeMKV new version v2.0.0 (20.9.2026)
#2 Post by cdheer » Wed Sep 23, 2026 7:29 pm
Same. And I get this:
Mikief12
#3 Post by Mikief12 » Wed Sep 23, 2026 8:57 pm
Ok, I had some weirdness on my Mac Mini.. I'm running MacOS 27.2 Beta. With 1.8, I can see the Blu-Ray drive just fine. When I installed 2.0, I could not.
And a number of apps crashed. (firefox, Brave got "stuck", etc..) Makemkv also wanted me to enable application management, something 1.8 doesn't.
Anyone else seeing "issues"?? I removed it from my Mac. I'll stick with 1.8 for now.
#4 Post by Woodstock » Thu Sep 24, 2026 1:32 am
MacOS is vary particular about versions. Have you specifically enabled 2.0.0 to run? Otherwise, it will consider it a danger to your system, and refuse it.
blind-s33r
#5 Post by blind-s33r » Thu Sep 24, 2026 2:10 pm
I have the same issue on linux compiling it myself... 1.18.4 works fine but 2.0.0 crashes when trying to open the disc or files...
Sayaka
#6 Post by Sayaka » Thu Sep 24, 2026 2:37 pm
Same here...
EDIT : The issue seems to come from the main makemkvcon binary, not the GUI.
16442496
#7 Post by 16442496 » Thu Sep 24, 2026 4:30 pm
Looks like it's fine here. BD's and DVD's works fine. MakeMKV-2.0.0 (Linux) from sources.
Sayaka
#8 Post by Sayaka » Thu Sep 24, 2026 4:55 pm
It doesn't work for me with an Ubuntu-based distro. Same with my Arch distrobox.
Ferrett1983
#9 Post by Ferrett1983 » Thu Sep 24, 2026 5:27 pm
I'll carry on using 1.18.4 for the time being until the issues resolved.
