pmar4015
Re: SDFtool Flasher
Post by pmar4015 »
I have tried several time but alas the flasher tool does not recognize the appropriate UHD drive. What is interesting is the MakeMKV application recognizes the drive and Windows Device Manager as well but some reason the SDFlasher tool (version 1.3.6) does not. I tried version 1.3.5 as well but still with no success.
At first I thought the problem may reside in the fact I am using Windows 11 on my Mac Mini via Parallels (and yes I am using an esata/usb connection directly connected to the Mac Mini) but when I tried using my son's Laptop PC (fully updated as of 9.23.2026 Windows 11 OS) the issues remained unchanged. I have attached various applicable screenshots that I hope will provide more insight into the matter. In any event, any help you can provide would be greatly appreciated (and please let me know what additional information is needed).
Many thanks,
PS. I will send remaining attachments via separate post
Cthulhu
Re: SDFtool Flasher
Post by Cthulhu »
hello I keep getting this error and have no idea what I'm doing wrong thanks for any help.
Re: SDFtool Flasher
Knowing WHAT error you are receiving would be helpful in aiding you in fixing it.
Cthulhu
Re: SDFtool Flasher
Post by Cthulhu »
Woodstock wrote: Thu Sep 24, 2026 1:18 am Knowing WHAT error you are receiving would be helpful in aiding you in fixing it.
sorry I had added a screen shot when I made the post but it didn't upload it's a Microsoft.net error that pops up when I open the SDFtool flasher.exe that says" Unhandled exception has occurred in your application. If you click continue the appllcation will ignore this error and attempt to continue.If you click quit, the application will close immediately.
An error occurred trying to start process 'C:\Program Files (x86)\MakeMKV\sdftool64.exe' with working directory 'C:\Program Files (x86)\MakeMKV' the system cannot find the file specified.
OS device name: G:
Product: BD-RE BU40N
Revision: U102
Serial number: **********
Firmware date: 2119-05-10 13:19
Bus encryption flags: 1F
also if it matters I'm on windows 11 fully up to date
willy
Re: SDFtool Flasher
Post by willy »
Cthulhu wrote: Thu Sep 24, 2026 1:37 am
OS device name: G:
Revision: U102
Hello
But I have exactly the same problem as Cthulhu.
I have included a photo of the problem for you.
Thank you for your help.
Re: SDFtool Flasher
willy wrote: Thu Sep 24, 2026 3:16 pm I have included a photo of the problem for you.
The storage available on the forum for posting photos & files is very limited and it is usually full and doesn't work, as it didn't for you.
Your best bet is to put a photo somewhere on the internet (https://imgur.com works well for example) and post a link here.
willy
Re: SDFtool Flasher
Post by willy »
Here is the link to the screenshot of the error message I received.
https://postimg.cc/D82Wctzv
Thank you ,dcoke22, for this information.
Cthulhu
Re: SDFtool Flasher
Post by Cthulhu »
willy wrote: Thu Sep 24, 2026 5:40 pm Here is the link to the screenshot of the error message I received.
This is exactly the same one Im getting thanks for posting a screenshot of it
Re: SDFtool Flasher
Cthulhu wrote: Thu Sep 24, 2026 5:51 pm
Which version of SDFtool Flasher are you using? The latter versions should all include .NET runtimes so that you don't have to install it yourself.
Also, ensure you have MakeMKV installed in the default location ('C:\Program Files (x86)\MakeMKV)
