Flashing Pioneer drives with firmware 12/2022+
skyrider
Post by skyrider » Fri Sep 18, 2026 9:02 pm
Since I own several Pioneer drives flashed with firmware released after December 2022, I've been looking for an effective method to downgrade and crossflash them to UHD versions. Until recently, the only person capable of downgrading these drives was Billycar11, who essentially had a full monopoly on the process.
Fortunately, this has just changed.
You no longer need to pay Billy $200 for a downgrade, because Trevor has stepped in and completely changed the situation.
As soon as I saw his post on cdrinfo forum, I contacted him directly. I sent him MakeMKV screenshots of all my drives with firmware released after 12/2022 so he could analyze them. In response, Trevor prepared a test version of his flasher for me, which allowed me to easily downgrade from BDR-XD05T 1.22 straight to BDR-XD06U 1.11 in a single step.
The program is very intuitive, comes with a graphical GUI, and Trevor was kind enough to prepare a Polish language manual as well. He is continuously expanding his database of kernels and firmware for Pioneer drives, so I believe it's worth supporting his work.
He has made his environment available at https://research.trev.bot/, where you can find the beta version of his Windows application. Its purpose is to collect information about the connected drive (model, kernel, firmware, MakeMKV data, etc.) and send it to Trevor's development server.
I contacted him via email at research@trev.bot. I received the flasher and assistance. The program is still in an early testing phase, so if any issues arise, we simply send Trevor the JSON files for analysis.
Below is a screenshot with information about my drive, which I bought some time ago with locked firmware (the previous owner had updated it).
Before:
After:
Looking for a Pioneer 4K UHD drive?
Click here
Re: Flashing Pioneer drives with firmware 12/2022+
Post by Billycar11 » Fri Sep 18, 2026 10:41 pm
There is something to be said about reverse engineering
Yethidran
Post by Yethidran » Sat Sep 19, 2026 4:19 am
Thanks for the info and heads up. Great!
cashkey1
Post by cashkey1 » Sat Sep 19, 2026 4:27 am
Thats Superb!!! Cheer's!!!
skyrider
Post by skyrider » Sat Sep 19, 2026 4:56 pm
Another Pioneer drive has been successfully downgraded thanks to Trevor.
This time it's the BDR‑XD07TB, which landed in my hands with the latest firmware already installed.
It is now fully ready to read 4K UHD discs.
Before:
After:
Click here
skyrider
Post by skyrider » Mon Sep 21, 2026 10:05 pm
trev.bot research beta 0.1.8 - full firmware captures requested.
Below I am including Trevor's request.
The new trev.bot research beta 0.1.8 build is now available at https://research.trev.bot/
Download here - https://research.trev.bot/downloads/Tre ... ws-x64.zip
All previously issued and valid beta invitation codes remains active.
This release focuses on expanding data collection with full firmware captures, not just basic identification.
After running "Identify", please proceed with "Capture and send firmware" including main firmware when the tool offers it.
Uploads are handled automatically. Once the server confirms receipt, the local capture is removed.
Any failed uploads remain encrypted and will be retried until successful.
Version 0.1.8 introduces six new exact read profiles for the BDR‑211M, 212BK, and 213M series.
These profiles still require physical validation, so every test run is highly appreciated.
The tool functions strictly as a research collector, it does not flash drives, so don't worry.
Even refused read diagnostics are valuable and help us improve support for additional models.
Thanks in advance for your help.
Click here
glider_pilot
Post by glider_pilot » Wed Sep 23, 2026 7:46 pm
Another success story.
Flashed Pioneer BD-RW BDR-XD07 to BDR-XD07U. In now can read UHD disks.
Before:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.06
Serial number: TIDL004642UC
Firmware date: 2024-10-09
Bus encryption flags: 13
Highest AACS version: 57
Drive platform: Pioneer RS8D30
Firmware version: GENE
After
Product: BD-RW BDR-XD07U
Revision: 1.04
Firmware date: 2022-05-31
Highest AACS version: 72
Drive platform: RS8D31
Firmware version: 1.04/ID05
Many thanks to the author!
skyrider
Post by skyrider » Wed Sep 23, 2026 10:12 pm
This time it's the BDR‑211UBK, which landed in my hands with the 1.54 firmware already installed.
Now successfully downgraded to 1.53.
Before:
After:
trev.bot 0.6.0-beta.5 brings the diagnostics work into the main trev.bot app. The biggest differences from the standalone diagnostic build are:
- Broader surveys: it keeps the existing firmware-capture methods and adds the verified XD08U 1.04 capture. Drives without an exact capture match now get additional capability probes instead of stopping at identification.
- Updates in the app: we can deliver new versions and research procedures through the signed updater.
- One app for research and supported flashing: the Research survey itself does not flash firmware.
- Automatic uploads remain: the diagnostic build already had these, and they’re now integrated into the main app, including encrypted storage and automatic retries when delivery fails.
Click here
skyrider
Post by skyrider » Wed Sep 23, 2026 10:15 pm
trev.bot 0.6.0-beta.11
UD03 flashing is available again. Fixed a completion-check error caused by two zero padding bytes in a valid Windows drive-status response. The app now continues its existing bounded completion checks and final firmware verification instead of stopping on that response.
No changes to firmware payloads, transfer commands or retry rules. A previous interrupted operation must not be repeated just to test this update; retain its journal and use the original app version for its saved verification workflow.
BDR-211 flashing remains paused. Existing keys, server-controlled route availability and automatic research survey uploads continue to work.
Click here
Yethidran
Post by Yethidran » Thu Sep 24, 2026 4:05 am
i have a pioneer BDR-UD02 which i flashed a long time ago to UD03 then UD04, but unfortunately the flashing it bricked it. i still have the drive with me. how do i upload using the trevor tool?
Yethidran
Post by Yethidran » Thu Sep 24, 2026 6:07 am
OS device name: \Device\CdRom5
Product: BD-RW BDR-UD02
Revision: 1.00
Serial number: LJDL050094WL
Firmware date: 2012-08-23
Highest AACS version: 68
Drive platform: RS8410
Firmware name: PIONEER BDR-US02
Firmware version: 1.00/ID19
Yethidran
Post by Yethidran » Thu Sep 24, 2026 6:09 am
this was the makemkv readout months ago, when it was on the stock ud-02 firmware.. but now its been upgraded to ud-04 firmware and it totally cannot read or write anything anymore. just a dead drive.
Post by Coopervid » Thu Sep 24, 2026 1:04 pm
Yethidran wrote: Thu Sep 24, 2026 6:09 am this was the makemkv readout months ago, when it was on the stock ud-02 firmware.. but now its been upgraded to ud-04 firmware and it totally cannot read or write anything anymore. just a dead drive.
UD02 can not be flashed to UD04. It's bricked.
Post by Billycar11 » Thu Sep 24, 2026 1:09 pm
Yethidran wrote: Thu Sep 24, 2026 6:07 am Drive Information
Revision: 1.00
Email me about this we have a ud03 flasher we maybe able to replace the ud02 fw in it to spoof it back worth a try but you will need to flash to a specific ud03 this flasher is targeting
Yethidran
Post by Yethidran » Thu Sep 24, 2026 2:56 pm
thanks billy, just wondering if there will be a "Charge" for that special ud03 firmware?
