MakeMKV new version v2.0.0 (20.9.2026)
Ferrett1983
I seem to be having a problem opening a blu-ray disc up on this version. It tries to open disc but then hangs/crashes.
cdheer
Re: MakeMKV new version v2.0.0 (20.9.2026)
Same. And I get this:
Mikief12
Ok, I had some weirdness on my Mac Mini.. I'm running MacOS 27.2 Beta. With 1.8, I can see the Blu-Ray drive just fine. When I installed 2.0, I could not.
And a number of apps crashed. (firefox, Brave got "stuck", etc..) Makemkv also wanted me to enable application management, something 1.8 doesn't.
Anyone else seeing "issues"?? I removed it from my Mac. I'll stick with 1.8 for now.
MacOS is vary particular about versions. Have you specifically enabled 2.0.0 to run? Otherwise, it will consider it a danger to your system, and refuse it.
blind-s33r
I have the same issue on linux compiling it myself... 1.18.4 works fine but 2.0.0 crashes when trying to open the disc or files...
Sayaka
Same here...1.18.4 works fine but 2.0.0 crashes when trying to open the disc or files...
EDIT : The issue seems to come from the main makemkvcon binary, not the GUI.
16442496
Looks like it's fine here. BD's and DVD's works fine. MakeMKV-2.0.0 (Linux) from sources.
Sayaka
It doesn't work for me with an Ubuntu-based distro. Same with my Arch distrobox.
Ferrett1983
I'll carry on using 1.18.4 for the time being until the issues resolved.
ShadeTC
I'll also add a report that v2 gives me the same error on a Windows install on Windows 10 with an BP60NB10 LG USB drive. Reverting back to 1.18.4 with the same disc and drive works with no errors.
rsaotome
Same, Fatal Error, Windows 10, reverting back to 1.18.4.
swest0223
I have a MakeMKV implementation on my UGREEN NAS, naturally it's the Unix version.
MakeMKV v2.0.0 linux(x64-release) and I'm having the same issue, where I can open DVD ISOs, but Bluray/UHD ISOs result in a "Fatal Error" and subsequent crash.
Has anyone patched the Unix version yet? Is there a way to revert back to the previous version?
