MakeMKV new version v2.0.0 (20.9.2026)
Ferrett1983
I seem to be having a problem opening a blu-ray disc up on this version. It tries to open disc but then hangs/crashes.
cdheer
Re: MakeMKV new version v2.0.0 (20.9.2026)
Same. And I get this:
Mikief12
Ok, I had some weirdness on my Mac Mini.. I'm running MacOS 27.2 Beta. With 1.8, I can see the Blu-Ray drive just fine. When I installed 2.0, I could not.
And a number of apps crashed. (firefox, Brave got "stuck", etc..) Makemkv also wanted me to enable application management, something 1.8 doesn't.
Anyone else seeing "issues"?? I removed it from my Mac. I'll stick with 1.8 for now.
MacOS is vary particular about versions. Have you specifically enabled 2.0.0 to run? Otherwise, it will consider it a danger to your system, and refuse it.
