Cthulhu
Re: SDFtool Flasher
Post by Cthulhu »
hello I keep getting this error and have no idea what I'm doing wrong thanks for any help.
Re: SDFtool Flasher
Knowing WHAT error you are receiving would be helpful in aiding you in fixing it.
Cthulhu
Re: SDFtool Flasher
Post by Cthulhu »
Woodstock wrote: Thu Sep 24, 2026 1:18 am Knowing WHAT error you are receiving would be helpful in aiding you in fixing it.
sorry I had added a screen shot when I made the post but it didn't upload it's a Microsoft.net error that pops up when I open the SDFtool flasher.exe that says" Unhandled exception has occurred in your application. If you click continue the appllcation will ignore this error and attempt to continue.If you click quit, the application will close immediately.
An error occurred trying to start process 'C:\Program Files (x86)\MakeMKV\sdftool64.exe' with working directory 'C:\Program Files (x86)\MakeMKV' the system cannot find the file specified.
OS device name: G:
Product: BD-RE BU40N
Revision: U102
Serial number: **********
Firmware date: 2119-05-10 13:19
Bus encryption flags: 1F
also if it matters I'm on windows 11 fully up to date
willy
Re: SDFtool Flasher
Post by willy »
Cthulhu wrote: Thu Sep 24, 2026 1:37 am
OS device name: G:
Revision: U102
Hello
But I have exactly the same problem as Cthulhu.
I have included a photo of the problem for you.
Thank you for your help.
Re: SDFtool Flasher
willy wrote: Thu Sep 24, 2026 3:16 pm I have included a photo of the problem for you.
The storage available on the forum for posting photos & files is very limited and it is usually full and doesn't work, as it didn't for you.
Your best bet is to put a photo somewhere on the internet (https://imgur.com works well for example) and post a link here.
willy
Re: SDFtool Flasher
Post by willy »
Here is the link to the screenshot of the error message I received.
https://postimg.cc/D82Wctzv
Thank you ,dcoke22, for this information.
Cthulhu
Re: SDFtool Flasher
Post by Cthulhu »
willy wrote: Thu Sep 24, 2026 5:40 pm Here is the link to the screenshot of the error message I received.
This is exactly the same one Im getting thanks for posting a screenshot of it
Runstile
Re: SDFtool Flasher
Post by Runstile »
I am getting the same error. It looks to me from reading everything that MakeMKV used have sdftool64.exe included, which the SDFTool Flasher looks for when starting up. Without it in the MakeMKV directory, it will not start up correctly. Is there a current work around, or an ETD for updated tool?
Re: SDFtool Flasher
Cthulhu wrote: Thu Sep 24, 2026 5:51 pm
Which version of SDFtool Flasher are you using? The latter versions should all include .NET runtimes so that you don't have to install it yourself.
Also, ensure you have MakeMKV installed in the default location ('C:\Program Files (x86)\MakeMKV)
willy
Re: SDFtool Flasher
Post by willy »
MartyMcNuts wrote: Fri Sep 25, 2026 1:14 am
Also, ensure you have MakeMKV installed in the default location (C:\Program Files (x86)\MakeMKV)
I used versions v1.3.6 and v1.3.5 of SDFtool. . And MakeMKV is properly installed on (C:\Program Files (x86)\MakeMKV).
Thank you for your help. :D
Cthulhu
Re: SDFtool Flasher
Post by Cthulhu »
willy wrote: Fri Sep 25, 2026 1:09 pm
I did the same as willy as well as reinstalling the .NET runtimes
Sayaka
Re: SDFtool Flasher
Post by Sayaka »
willy
Re: SDFtool Flasher
Post by willy »
Sayaka wrote: Fri Sep 25, 2026 3:55 pm Please see here : viewtopic.php?p=205718#p205718
Check out the discussion thread; he proposed a solution that works!
Thanks to Sayaka !!!
Re: SDFtool Flasher
First post updated bu basically don't try flashing your drive using MakeMKV v2.0.0 as sdftool64.exe wasn't included therefore SDFtool Flasher cannot find it and throws an error.
Considering the amount of issues that v2.0.0 has, I'm surprised it was even released! I certainly won't be installing it. I'll stick with 1.18.4.
zittrig
Re: SDFtool Flasher
Post by zittrig »
Thanks, Marty, I already was wondering 'cause of the error :)
