IN STOCK! (Worldwide, eBay, PayPal, CC) BRAND NEW Pioneer BDR-S09XLT, BDR-S08XLT, BDR-209DBK Drives - 4K/UHD - Tested
Gnarlyteeth
Re: IN STOCK! (Worldwide) BRAND NEW Pioneer BDR-S09XLT, BDR-S08XLT, BDR-209DBK Drives - 4K/UHD - Flashed & Tested
Post by Gnarlyteeth »
I received my drive a couple of days ago, it's legit and comes preflashed as the seller claims since makemkv reports libredrive is enable. When it comes to actually ripping I had issues, I hope they're just because I tested using a sata to usb adapter since my 5.5" slot in my computer already houses another drive.
PistolPete76
Post by PistolPete76 »
Gnarlyteeth wrote: Tue Aug 25, 2026 1:35 pm I received my drive a couple of days ago, it's legit and comes preflashed as the seller claims since makemkv reports libredrive is enable. When it comes to actually ripping I had issues, I hope they're just because I tested using a sata to usb adapter since my 5.5" slot in my computer already houses another drive.
I’m no uber expert but based on what I’ve read about different drives on this forum, what people have discussed on here and comments read on other discussion platforms then base on your explanation of how you connected the drive up via USB I’m wondering if the drive didn’t have enough power (amps) to operate correctly…..
The drive is designed for internal PC mounting and would be powered off the amply capable PC power supply.
When these internal drives are used externally over USB they are normally mounted in an external case which has a separate power brick adapter that plugs into the wall outlet to provide the drive with ample power/amperage.
So if it was connected in the basic fashion as you explained it you would most likely require at a bare minimum a dual USB-A connector to SATA so when you connect to your computer you are plugging in 2 USB-A plugs to get twice the amperage by combining two ports output power to the drive so it doesn’t start to glitch under heavy load and draw such as spinning the disc, powering the laser head, and moving the head back and forth.
All this draws more current/amps from the PC USB ports to achieve than just powering the drive up and interrogating its settings and firmware with MakeMKV.
I hope my explanation helps and makes sense.
Alternatively you could have been using a dual USB-A lead or another means of externally powering the drive which you haven’t explained that has lead me to my assumption and answer.
Gnarlyteeth
PistolPete76 wrote: Tue Aug 25, 2026 2:22 pm
I used a sata to usb adapter with an incorporated power supply, like so: https://www.amazon.com.mx/sata-a-usb/s?k=sata+a+usb
Gnarlyteeth wrote: Wed Aug 26, 2026 2:24 am
This one is recommended. Most others don't allow flashing and are also only supposed to work with HDD. This one supports optical drives 100%.
https://www.amazon.com.mx/Benfei-Adapte ... 5a71b&th=1
PistolPete76
Coopervid wrote: Wed Aug 26, 2026 9:48 am
Is that one recommended because of full UASP pass through support?
PistolPete76 wrote: Wed Aug 26, 2026 12:06 pm
Yes. And it supports all SCSI commands for flashing all optical drives. Many adapters and even enclosures don't.
hcmilli
Post by hcmilli »
Hey, I just got on the preorder list on your website. Do you still have some drives available? I’m a new user, so I don’t think I’ll be able to respond to DMs
Gnarlyteeth
Gnarlyteeth wrote: Wed Aug 26, 2026 2:24 am I used a sata to usb adapter with an incorporated power supply, like so: https://www.amazon.com.mx/sata-a-usb/s?k=sata+a+usb
I already used my adapter to flash my LG WH14NS40 to rip 4K Blu-Rays so who knows. I'll properly test the Pioneer drive (I forgot to mention I got the BDR-S09XLT) and connect it to my server after I come back from vacations :mrgreen:
Gnarlyteeth wrote: Wed Aug 26, 2026 3:58 pm
Is yours flashed to 211 / S11 for UHD? If not contact me. The Pioneers are not easy to flash with cheap USB->SATA adapters. Just to let you know.
ceski23
Re: IN STOCK! (Worldwide) BRAND NEW Pioneer BDR-S09XLT, BDR-S08XLT, BDR-209DBK Drives - 4K/UHD - Tested
Post by ceski23 »
I've got my BDR-S09XLT yesterday. It was delivered to Poland in about week. Drive came in original OEM box, it's libredrive-enabled. I tested it on few Blu-rays and it works flawlessly. I'm using it with ICY BOX IB-525-U3 enclosure without any problems.
thedood365
Post by thedood365 »
+1 for levtrocki
Received in central US in a little over a week after making payment. Drive is legit, came LibreDrive enabled, and I've already ripped a couple of Blu-rays without issue.
wotnoob
Post by wotnoob »
Interested in buying one. Please DM me.
levtrocki
Re: IN STOCK! (Worldwide, eBay, PayPal, CC) BRAND NEW Pioneer BDR-S09XLT, BDR-S08XLT, BDR-209DBK Drives - 4K/UHD - Teste
Post by levtrocki »
Back in stock for BDR-S08XLT and BDR-209DBK! You can buy directly from our website or eBay.
Note: US payments fail around 50% of the time due to strict 3D security policies on the website, so we also added eBay/PayPal option for US customers (with an extra fee to compensate for the eBay commission)
BDR-S09XLT will be in stock on 03 October 2026!
We hope to resolve the remaining payment issues by then.
4K/UHD Drives for sale: viewtopic.php?p=202346
Website: https://uhdarchive.com
Contact: sales@uhdarchive.com
levtrocki
Post by levtrocki »
3D Secure problem with US payments have been resolved!
Confirmed: 10 units of model S09XLT on the 3rd of October! The price will be $400 for new buyers (pre-orders after 23.09.2026)
Hammerbo
Post by Hammerbo »
I reside in western Canada. The Pioneer BDR-S09XLT was delivered within six days of my purchase order. Arrived securely packaged in its original manufacturer's box. The drive is compatible with my Vantec NexStar DX2 enclosure. It comes pre-flashed and capable of playing 4K/UHD discs out of box. The service provided was exceptional. Get one before they run out.
