I tried many things but in the end I always get this output in KeyDB Assistant:
DISC INFORMATION
Validation Data : 2A2181E8358D17387B319EDCB9A20D5A
Media Key : 81E7FAD69C8E0B09F22823C5DB62D9D1
VUK : 498C803DDA0716B3A11865DD6DDE991B
Unit Key 1 : FAE480F144071E7B12499A3C4320D9ED
Unit Key 2 : 85581552DC02679109AF39A4EA5077EB
Unit Key 3 : 745FBD07ECCCDBE0CB5B5ABBDF91B6BB
Unit Key 4 : 376A2257B3A052F4DD5C72DC681D50D2
Unit Key 5 : 165F65F18A36137322E959D3C52D4505
Unit Key 6 : 80EB121AE1CB97571F04CAA314AED7DB
Unit Key 7 : 19F042FB453640883581AECE412B5887
Unit Key validation failed with 3 aligned units
--- Disc Information ---
Disc ID : 0x0EC4C2461006AA0D5B52DBAA0FE3CACAB29C2A1D
Volume : Predator
Title : Predator
Date : 2013-10-10
Disc Type : Blu-ray
Encryption Keys:
Media Key : 0x81E7FAD69C8E0B09F22823C5DB62D9D1
VID : 0x15675A7AA2666320C2BF1FC3ADC5A3B6
VUK : 0x498C803DDA0716B3A11865DD6DDE991B
MKB Version : 35
Unit Keys (7):
[1] 0xFAE480F144071E7B12499A3C4320D9ED
[2] 0x85581552DC02679109AF39A4EA5077EB
[3] 0x745FBD07ECCCDBE0CB5B5ABBDF91B6BB
[4] 0x376A2257B3A052F4DD5C72DC681D50D2
[5] 0x165F65F18A36137322E959D3C52D4505
[6] 0x80EB121AE1CB97571F04CAA314AED7DB
[7] 0x19F042FB453640883581AECE412B5887
KeyDB Status:
Database : (VALIDATED)
Status : complete
Unit Key validation failed with 3 aligned unitsI mean I can decrypt the disc using MakeMKV, I am just curious why KeyDB Assistant reports that error all over again.
I am using BH50N LibreDrive enabled.
The FindVUK output is here:
18:45:03 - ----------- FindVUK 2.08 x64 -----------
To close FindVUK simply press the ESC key
18:45:03 - SettingsFile: >C:\Prgwin\KeyDB_Assistant\FindVUK\config\FindVUK.ini<
18:45:03 - Logfile >C:\Prgwin\KeyDB_Assistant\FindVUK\log\2026-09-23_FindVUK.txt< Default Loglevel >2<
18:45:03 - Update enabled - check for update
18:45:03 - No update required
18:45:03 - Check for files to retry upload
18:45:03 - Nothing to retry found.
18:45:03 - Open Main-KEYDB file: >C:\Users\60fps\AppData\Roaming\aacs\KEYDB.cfg<
18:45:08 - Open Backup-KEYDB file: >C:\Prgwin\KeyDB_Assistant\FindVUK\VUKbackup\KEYDB.cfg<
18:45:08 - DVDfab Version >13.0.6.7< found
18:45:08 - >>> everything should work as expected!
18:45:08 - Preferred application >PassKey< is not available
18:45:08 - DVDfab is available!
18:45:08 - DVDfab-MainFile: >C:\Program Files\DVDFab\DVDFab 13\DVDFab64.exe<
18:45:08 - DVDfab-LogFile: >C:\Users\60fps\Documents\DVDFab\DVDFab13\Log\DVDFab13.log<
18:45:08 - KEYDB-Path: >C:\Users\60fps\AppData\Roaming\aacs\<
18:45:08 - KEYDB-Backup-Path: >C:\Prgwin\KeyDB_Assistant\FindVUK\VUKbackup\<
18:45:08 - ProcDumpFile: >C:\Prgwin\KeyDB_Assistant\FindVUK\tool\procdump64.exe<
18:45:08 - --- PART 1 --- GET DUMP ---
18:45:08 - No running application process discovered
18:45:08 - >> Start it now >C:\Program Files\DVDFab\DVDFab 13\DVDFab64.exe<
18:45:08 - Watching logfile of >DVDFab64<
18:45:22 - Drive opened
18:45:22 - Volume Label detected >Predator<
18:45:23 - DriveLetter detected >E<
18:45:24 - Detected CopyProtections AACS >1< BD+ >1<
18:45:24 - DiscID found >0EC4C2461006AA0D5B52DBAA0FE3CACAB29C2A1D<
18:45:49 - DVDFab64 got Unit Keys - create memdump now!
18:45:52 - Dump successful! >1<
18:45:52 - MemDump successfully finished!
18:45:52 - Cancel DVDfab decryption now!
18:45:52 - Get basic AACS data
18:45:53 - AACS folder >E:\AACS< on disc is reachable - Validate is possible
18:45:55 - VolumeName >Predator<
18:45:55 - VolumeSize >44437340160<
18:45:55 - DiscId >0EC4C2461006AA0D5B52DBAA0FE3CACAB29C2A1D< (2013-10-10)
18:45:55 - DiscType >BD<
18:45:55 - MKB Revision >35<
18:45:55 - Disc-BusEncEnabled >1<
18:45:55 - Drve-BusEncCapable >1<
18:45:55 - ==> Bus Encryption active!
18:45:55 - UnitKeyCount >7<
18:45:55 - >>> UnitKeyENC (1) >96660EE0DBC9C5315C6DAFCD2E60209D<
18:45:55 - >>> UnitKeyENC (2) >BB8FECE34B33DDB345E0AAED3A936F05<
18:45:55 - >>> UnitKeyENC (3) >5734F693447662AFD37520581600A29D<
18:45:55 - >>> UnitKeyENC (4) >174B3E3184CB83893009CD766E3CA64B<
18:45:55 - >>> UnitKeyENC (5) >A7B90938EEE4FB1F5342CD07DA6B1170<
18:45:55 - >>> UnitKeyENC (6) >F420042BE9D8E92FC8CE1D4548026EF3<
18:45:55 - >>> UnitKeyENC (7) >91F2A74928D09A4239A4F8FE266C9257<
18:45:55 - Analyze dump
18:45:55 - Start to analyze '2018' MemDump now!
18:46:01 - DiscID >0EC4C2461006AA0D5B52DBAA0FE3CACAB29C2A1D<
18:46:01 - UnitKeyCount >7<
18:46:01 - >>> UnitKeyDEC (1) >FAE480F144071E7B12499A3C4320D9ED<
18:46:01 - >>> UnitKeyDEC (2) >85581552DC02679109AF39A4EA5077EB<
18:46:01 - >>> UnitKeyDEC (3) >745FBD07ECCCDBE0CB5B5ABBDF91B6BB<
18:46:01 - >>> UnitKeyDEC (4) >376A2257B3A052F4DD5C72DC681D50D2<
18:46:01 - >>> UnitKeyDEC (5) >165F65F18A36137322E959D3C52D4505<
18:46:01 - >>> UnitKeyDEC (6) >80EB121AE1CB97571F04CAA314AED7DB<
18:46:01 - >>> UnitKeyDEC (7) >19F042FB453640883581AECE412B5887<
18:46:01 - BusDecryption is required - try to get ReadDataKey from dump
18:46:01 - >>> ReadDataKey from dump >83E66CA3F854D5E7E3C31EE4653B6B86<
18:46:01 - BusEncryption enabled => either ReadDataKey or disabling of BusEncryption required
18:46:01 - External tool to disable bus encryption defined >"C:\Program Files (x86)\MakeMKV\makemkvcon64.exe" info dev:$DRIVE$ <
18:46:05 - External tool successfully disabled BusEncryption!
18:46:05 - --- PART 2 --- VALIDATE VUK/UNITKEYS ---
18:46:05 - Drive is detected as 'REAL BLURAY' drive
18:46:05 - M2TS files found >168<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00720.m2ts< with UnitKey >2<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00908.m2ts< with UnitKey >1<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00910.m2ts< with UnitKey >1<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00909.m2ts< with UnitKey >1<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00953.m2ts< with UnitKey >1<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00911.m2ts< with UnitKey >1<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00954.m2ts< with UnitKey >1<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00912.m2ts< with UnitKey >1<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00955.m2ts< with UnitKey >1<
18:46:06 - Decrypted first unit of file >E:\BDMV\STREAM\00913.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00956.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00914.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00957.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00915.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00958.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00916.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00959.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00917.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00960.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00918.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00961.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00919.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00920.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00921.m2ts< with UnitKey >1<
18:46:07 - Decrypted first unit of file >E:\BDMV\STREAM\00962.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00922.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00963.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00923.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00964.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00924.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00965.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00925.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00966.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00926.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00967.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00927.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00968.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00928.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00969.m2ts< with UnitKey >1<
18:46:08 - Decrypted first unit of file >E:\BDMV\STREAM\00929.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00970.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00930.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00931.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00932.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00971.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00933.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00972.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00934.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00973.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00935.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00974.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00936.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00975.m2ts< with UnitKey >1<
18:46:09 - Decrypted first unit of file >E:\BDMV\STREAM\00937.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00976.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00938.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00977.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00939.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00978.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00940.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00979.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00941.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00942.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00943.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00980.m2ts< with UnitKey >1<
18:46:10 - Decrypted first unit of file >E:\BDMV\STREAM\00944.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00981.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00945.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00982.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00946.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00983.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00947.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00984.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00948.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00985.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00949.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00986.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00950.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00987.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00951.m2ts< with UnitKey >1<
18:46:11 - Decrypted first unit of file >E:\BDMV\STREAM\00988.m2ts< with UnitKey >1<
18:46:12 - Decrypted first unit of file >E:\BDMV\STREAM\00952.m2ts< with UnitKey >1<
18:46:12 - Decrypted first unit of file >E:\BDMV\STREAM\00989.m2ts< with UnitKey >1<
18:46:12 - Decrypted first unit of file >E:\BDMV\STREAM\01074.m2ts< with UnitKey >1<
18:46:12 - Decrypted first unit of file >E:\BDMV\STREAM\01075.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\01079.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\01081.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\00050.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\01293.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\01622.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\01715.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\01716.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\01078.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\01080.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\00101.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\00102.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\00103.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\00104.m2ts< with UnitKey >1<
18:46:13 - Decrypted first unit of file >E:\BDMV\STREAM\00105.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\00106.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\00107.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\00108.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\00109.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\00110.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01018.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01019.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01020.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01021.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01022.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01023.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01024.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01025.m2ts< with UnitKey >1<
18:46:14 - Decrypted first unit of file >E:\BDMV\STREAM\01026.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01027.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01028.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01029.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01030.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01031.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01032.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01033.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01034.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01035.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01036.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01037.m2ts< with UnitKey >1<
18:46:15 - Decrypted first unit of file >E:\BDMV\STREAM\01038.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01039.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01040.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01041.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01045.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01051.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01052.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01053.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01054.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01055.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01056.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01057.m2ts< with UnitKey >1<
18:46:16 - Decrypted first unit of file >E:\BDMV\STREAM\01058.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01060.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01061.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01062.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01063.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01064.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01065.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01066.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01067.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01068.m2ts< with UnitKey >1<
18:46:17 - Decrypted first unit of file >E:\BDMV\STREAM\01069.m2ts< with UnitKey >1<
18:46:18 - Decrypted first unit of file >E:\BDMV\STREAM\01071.m2ts< with UnitKey >1<
18:46:18 - Decrypted first unit of file >E:\BDMV\STREAM\01072.m2ts< with UnitKey >1<
18:46:18 - Decrypted first unit of file >E:\BDMV\STREAM\01073.m2ts< with UnitKey >1<
18:46:18 - Decrypted first unit of file >E:\BDMV\STREAM\00133.m2ts< with UnitKey >1<
18:46:18 - Decrypted first unit of file >E:\BDMV\STREAM\01257.m2ts< with UnitKey >1<
18:46:19 - Decrypted first unit of file >E:\BDMV\STREAM\01279.m2ts< with UnitKey >1<
18:46:19 - Decrypted first unit of file >E:\BDMV\STREAM\01280.m2ts< with UnitKey >1<
18:46:19 - Decrypted first unit of file >E:\BDMV\STREAM\01289.m2ts< with UnitKey >1<
18:46:19 - Decrypted first unit of file >E:\BDMV\STREAM\01290.m2ts< with UnitKey >1<
18:46:19 - Decrypted first unit of file >E:\BDMV\STREAM\01042.m2ts< with UnitKey >1<
18:46:19 - Decrypted first unit of file >E:\BDMV\STREAM\01755.m2ts< with UnitKey >1<
18:46:19 - Decrypted first unit of file >E:\BDMV\STREAM\01043.m2ts< with UnitKey >1<
18:46:20 - Decrypted first unit of file >E:\BDMV\STREAM\01756.m2ts< with UnitKey >1<
18:46:20 - Decrypted first unit of file >E:\BDMV\STREAM\01757.m2ts< with UnitKey >1<
18:46:21 - Decrypted first unit of file >E:\BDMV\STREAM\01758.m2ts< with UnitKey >1<
18:46:21 - Decrypted first unit of file >E:\BDMV\STREAM\01759.m2ts< with UnitKey >1<
18:46:21 - Decrypted first unit of file >E:\BDMV\STREAM\01760.m2ts< with UnitKey >1<
18:46:21 - Decrypted first unit of file >E:\BDMV\STREAM\01761.m2ts< with UnitKey >1<
18:46:22 - Decrypted first unit of file >E:\BDMV\STREAM\01762.m2ts< with UnitKey >1<
18:46:22 - Decrypted first unit of file >E:\BDMV\STREAM\01763.m2ts< with UnitKey >1<
18:46:22 - Decrypted first unit of file >E:\BDMV\STREAM\01764.m2ts< with UnitKey >1<
18:46:22 - Validation successful! UnitKeys are valid!!
18:46:22 - Disc with ID >0EC4C2461006AA0D5B52DBAA0FE3CACAB29C2A1D< is already in file - need to compare the details
18:46:22 - -------------------------------------------------------
18:46:22 - MetaTitle : Predator
18:46:22 - VolumeName : Predator
18:46:22 - DiscID : 0EC4C2461006AA0D5B52DBAA0FE3CACAB29C2A1D
18:46:22 - DateDiscID : 2013-10-10
18:46:22 - DiscType : BD
18:46:22 - VUK : 498C803DDA0716B3A11865DD6DDE991B
18:46:22 - MEDIAKEY : 81E7FAD69C8E0B09F22823C5DB62D9D1
18:46:22 - VOLUMEID : 15675A7AA2666320C2BF1FC3ADC5A3B6
18:46:22 - >>> UnitKeyDEC (1) >FAE480F144071E7B12499A3C4320D9ED< (Valid)
18:46:22 - >>> UnitKeyDEC (2) >85581552DC02679109AF39A4EA5077EB< (Valid)
18:46:22 - >>> UnitKeyDEC (3) >745FBD07ECCCDBE0CB5B5ABBDF91B6BB< (Unused)
18:46:22 - >>> UnitKeyDEC (4) >376A2257B3A052F4DD5C72DC681D50D2< (Unused)
18:46:22 - >>> UnitKeyDEC (5) >165F65F18A36137322E959D3C52D4505< (Unused)
18:46:22 - >>> UnitKeyDEC (6) >80EB121AE1CB97571F04CAA314AED7DB< (Unused)
18:46:22 - >>> UnitKeyDEC (7) >19F042FB453640883581AECE412B5887< (Unused)
18:46:22 - MKBrev : 35
18:46:22 - BusEncrEn : 1
18:46:22 - AACS : 1
18:46:22 - BD+ : 1 - Date 2013.11.04 / Gen 17
18:46:22 - --- Write entry in main-keydb file ---
18:46:22 - Keys in Keyfile: 187348 keys - KeyFile: C:\Users\60fps\AppData\Roaming\aacs\KEYDB.cfg
18:46:22 - KEYDB: Identical entry already present in keydb-file
18:46:22 - >> Identical: TITLE, VUK, DATE, MEDIAKEY, VOLUMEID, UNITKEYS, COMMENT - Different: nothing >> will NOT write new entry in keydb-file
18:46:22 - Identical entry already present in keydb-file - file is not changed
18:46:22 - --- Write entry in backup-keydb file ---
18:46:22 - Keys in Keyfile: 36 keys - KeyFile: C:\Prgwin\KeyDB_Assistant\FindVUK\VUKbackup\KEYDB.cfg
18:46:22 - KEYDB: entry for this disc already present in keydb-file
18:46:22 - >> no VUK available - >> write new entry in keydb-file
18:46:22 - Added line with VUK/UnitKeys to file >C:\Prgwin\KeyDB_Assistant\FindVUK\VUKbackup\KEYDB.cfg<
18:46:22 - --- Upload MetaXML to OnlineDB file ---
Establishing connection
HTTP-POST success
18:46:22 - Successfully posted to the OnlineDB! >
Preconditions fulfilled - process upload now
Detected BlurayMetaXML - DiscId >0EC4C2461006AA0D5B52DBAA0FE3CACAB29C2A1D<
Upload written to database!
Meta-Upload successfully processed!
18:46:22 - Successful upload to OnlineDB
18:46:22 - Eject the disc now from drive >E:\<
18:46:27 - Successfully ejected the media in drive E!
18:46:27 - ExitAfterProcessing is set to >1< - exit now
18:46:27 - CloseAtTheEnd is active, close DVDfab now
Please press ENTER or ESC to exit
