Public KeyDB Disc Submissions
AnBird
#3061 Post by AnBird » Sat Sep 19, 2026 10:36 am
Disc type: UHD
Disc ID: c5e19c323411fc352f3a42d711b8995335b23aa4
Disc dump filename: MKB20_v76_Red_Dawn_(1984)_FA55.tgz
Drive: WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
dump and MKB_RO.inf link: https://mega.nz/folder/RIgn1ZYa#lqnSUFVMGbn-NGyoM7e01w
BlessedCheesemaker
#3062 Post by BlessedCheesemaker » Sat Sep 19, 2026 12:18 pm
Interview with a Vampire
Disc type: UHD
Disc ID: 6683cf3a34cb253e401f980d73ecf060d2f4952b
Disc dump filename: MKB20_v82_Interview_with_the_Vampire-_The_Vampire_Chronicles_D1FC
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1jwoh64 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1bhOq5S ... sp=sharing
keydb_helper
#3063 Post by keydb_helper » Sat Sep 19, 2026 4:11 pm
AnBird wrote: Sat Sep 19, 2026 10:36 am Disc type: UHD
BlessedCheesemaker wrote: Sat Sep 19, 2026 12:18 pm Disc type: UHD
Thanks for the new disc dump files. Both of your discs have been added to the public keydb.
Scottland95 wrote: Sat Sep 19, 2026 8:54 am OUT OF THE PAST 4K UHD
Disc type: BD-ROM UHD
Disc ID: 6eed72539c7923f9000e225dbe2111fa19561ac6
Your disc was added to the public keydb on September 13. Please check the latest public keydb before posting here.
KeyDB Download
gloss
#3064 Post by gloss » Sat Sep 19, 2026 6:41 pm
Look Back
Disc type: UHD
Disc ID: f01abf18e28fe9700ebd1808821acbd98c39654c
Disc dump filename: MKB20_v82_Look_Back_858D
Drive: BDDVDRW UH12NS40
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link: https://we.tl/t-e9vNF2wDCDFQxixT
Disc dump link: https://we.tl/t-e9vNF2wDCDFQxixT
buffalobossie
#3065 Post by buffalobossie » Sat Sep 19, 2026 9:03 pm
Rad
Disc type: UHD
Disc ID: a0eaec9b33ce20c09766ccee0adf0691b14b96bb
Disc dump filename: MKB20_v82_Rad_UHD_6A17.tgz
Drive: BD-RE WH16NS60
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1BCb5Sn ... sp=sharing
Disc dump link: https://drive.google.com/file/d/13xJHTR ... sp=sharing
Sweet Sixteen
Disc type: UHD
Disc ID: e261ecb14ab2d085150223e3a8ce03cf2c526ca3
Disc dump filename: MKB20_v82_VS545UHD_4F17.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1FDRZ9l ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Gd7ALg ... sp=sharing
The Murder Secret
Disc type: UHD
Disc ID: bbefc2d520aba8b0487742f2d2508740acd46859
Disc dump filename: MKB20_v82_VS544UHD_FBD7.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1KL1z4- ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1h0Bkfp ... sp=sharing
Fear No Evil
Disc type: UHD
Disc ID: a96c7602d786d7718b10021058c6261b3b97e931
Disc dump filename: MKB20_v82_VS543UHD_1419.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1evpqRl ... sp=sharing
Disc dump link: https://drive.google.com/file/d/10nmI1r ... sp=sharing
MKVDUDE
#3066 Post by MKVDUDE » Sat Sep 19, 2026 11:25 pm
Hi - Another batch please - All files are in the same link -https://we.tl/t-KHFV0ymwAVLEK8g2
Disc type: UHD
Disc ID:1394f25b82845eb2c0917184a16ff9b56aa2bbcd
Disc dump filename:MKB20_v82_Above_the_Law_6716.tgz
Drive: MT1959
Drive firmware: 1.03
MKB_RO.inf link:https://we.tl/t-KHFV0ymwAVLEK8g2
Disc dump link:https://we.tl/t-KHFV0ymwAVLEK8g2
Disc type: UHD
Disc ID:625bef7ad0ccc34ee8f2a8f9cb2ec3f03df871bb
Disc dump filename:MKB20_v82_The_Corruptor_05D8.tgz
Drive: MT1959
Disc type: BD
Disc ID:35be3e0d3c2631a2e10b3ecf373f340ff40ea9bf
Disc dump filename:MKB_v82_High_Road_to_China_F7BC.tgz
Drive: MT1959
Disc type: UHD
Disc ID:5350796a88522c4b04c10f888fccaccdb646d19b
Disc dump filename:MKB20_v82_Trick_or_Treat_2034.tgz
Drive: MT1959
Many thanks!
keydb_helper
#3067 Post by keydb_helper » Sun Sep 20, 2026 12:08 pm
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB_v82_High_Road_to_China_F7BC
*MKB20_v61_A_FEW_GOOD_MEN (0x466129D6847A44ECA0AEAEB8AB3CC9024062BCBD)
*MKB20_v82_Above_the_Law_6716
*MKB20_v82_GO (0xFF326D1FEFE5841C7DC5D37213382AA2ACAE42AA)
*MKB20_v82_The_Corruptor_05D8
*MKB20_v82_Trick_or_Treat_2034
KeyDB Download
TheNipanen
#3068 Post by TheNipanen » Sun Sep 20, 2026 8:05 pm
MartyMcNuts wrote: Fri Sep 18, 2026 10:54 pm Clean the disc!!
keydb_helper wrote: Sat Sep 19, 2026 2:23 am As Marty noted, cleaning the disc is a good first step. It might also be worth running some RAM or disk diagnostics on the off chance there is a separate hardware fault interfering with the disc backup.
Thanks for the help, cleaning the disc worked! It's a brand new one so I did not think to do that. I guess there can be some factory residue that interferes with reading the disc.
#3069 Post by MartyMcNuts » Mon Sep 21, 2026 2:05 am
TheNipanen wrote: Sun Sep 20, 2026 8:05 pm
Yes, this often happens with 4k UHD discs, probably about 75% of the time. Best to always give the disc a clean the first time you take it out of the case.
Happy_Camper
#3070 Post by Happy_Camper » Mon Sep 21, 2026 9:37 pm
Disc type: BD
Disc ID: F9DD3FA1C636EC47124BB4B32B3BA3B75ECBC89C
Disc dump filename: ?, not sure what program is actually used that makes the dump file for these posts.
Disc dump link: https://www.mediafire.com/file/zombhqvy ... e.rar/file
Disc Name: DUE_DATE
The methods I did was also tested, the keys work, and was verified by a different application that's in the rar.
Last edited by Happy_Camper on Tue Sep 22, 2026 10:18 pm, edited 2 times in total.
limitofzero
#3071 Post by limitofzero » Mon Sep 21, 2026 11:16 pm
Angel's Egg
Disc type: UHD
Disc ID: 095113a09c212821cdf1aa32c17a781f3c138e2d
Disc dump filename: MKB20_v82_Angel's_Egg_-_4K_UHD_4555
Drive: BP60NB10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1TI5zzH ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1ljwIq1 ... sp=sharing
keydb_helper
#3072 Post by keydb_helper » Wed Sep 23, 2026 1:16 pm
Thanks to everyone who followed the template and provided new disc dump files. The following BD and UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB_v82_DAVID5460_1_DIDANewBeginning_D1_3A06
*MKB_v82_DAVID5460_2_DIDANewBeginning_D2_C2B6
KeyDB Download
skinnypope
#3073 Post by skinnypope » Wed Sep 23, 2026 1:28 pm
The Secret Agent (2025) UHD
Disc type: UHD
Disc ID: 17b1b1a6e72220fd651230101b8a89fe445e7b3b
Disc dump filename: MKB20_v82_MUBI059U_3B94
Drive: BD-RW BDR-XD08U
Drive firmware: 1.01
MKB_RO.inf link: https://drive.google.com/file/d/1pOZpmw ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1H9Cct8 ... sp=sharing
keydb_helper
#3074 Post by keydb_helper » Wed Sep 23, 2026 1:44 pm
skinnypope wrote: Wed Sep 23, 2026 1:28 pm The Secret Agent (2025) UHD
Disc type: UHD
Hey skinnypope, thanks for the new submission. Your disc has been added to the public keydb.
KeyDB Download
