Only audio is produced
mczocker32
Post by mczocker32 » Mon Sep 21, 2026 5:45 pm
Hello
I have a Minority Reports BD that generates MKVs lacking video, though only for certain featurettes. The MakeMKV title overview displays the file normally, yet the output contains only audio and is under 100 MB in size. Does anyone know what to do?
Ezatoka
Re: Only audio is produced
Post by Ezatoka » Mon Sep 21, 2026 10:18 pm
Which video codec does MakeMKV show for these tracks? Maybe your player can't handle the codec.
mczocker32
Post by mczocker32 » Tue Sep 22, 2026 6:14 am
Ezatoka wrote: Mon Sep 21, 2026 10:18 pm Which video codec does MakeMKV show for these tracks? Maybe your player can't handle the codec.
Everything is H264 also the video just isn’t present. It outputs a 9 minute video as a ~39 MB file without any video.
Ezatoka
Post by Ezatoka » Tue Sep 22, 2026 6:48 am
You can't deselect video tracks in MakeMKV (except 3D parts) so every movie should have a video.
Can you check the resulting MKV files with something like MediaInfo?
mczocker32
Post by mczocker32 » Tue Sep 22, 2026 9:36 am
Ezatoka wrote: Tue Sep 22, 2026 6:48 am You can't deselect video tracks in MakeMKV (except 3D parts) so every movie should have a video.
The file does have a video track thats shows H.264, en, 0, 1920x1080 but the mkv is 41.114 KB in size and can't possibly hold a real video track. Everything stripped except the video track produces a 17.725 KB file.
Name der Quelldatei: 00457.mpls
Länge: 0:09:35
Anzahl der Kapitel: 2
Segmentanzahl: 1
Segmentkarte: 922
Name der Ausgabedatei: Minority Report_t01.mkv
Video
ID im ursprünglichen Quellmedium : 4113 (0x1011)
Format : AVC
Format/Info : Advanced Video Codec
Format-Profil : High@L4.1
Format-Einstellungen : CABAC / 4 Ref Frames
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für RefFrames : 4 frames
Format-Einstellungen für GOP : M=3, N=30
Format-Einstellungen für Anzahl der Slic : 4 Slices pro Frame
Codec-ID : V_MPEG4/ISO/AVC
Dauer : 9 min 35s
Bitraten-Modus : Konstant
Bitrate : 252 kb/s
Nominale Bitrate : 1 000 kb/s
Breite : 1 920 Pixel
Höhe : 1 080 Pixel
Bildseitenverhältnis : 16:9
Modus der Bildrate : konstant
Bildrate : 29,970 (30000/1001) FPS
Farbraum : YUV
Farbunterabtastung : 4:2:0
Bittiefe : 8 bits
Scantyp : MBAFF
Speicher-Verfahren des Scantyps : Felder sind interleaved
Scanreihenfolge : oberes Feld zuerst
Bits/(Pixel*Frame) : 0.004
Stream-Größe : 17,3 MiB (43%)
Sprache : Englisch
Standard : Nein
Erzwungen : Nein
Farbspektrum : Limited
Primärfarben : BT.709
Übertragungscharakteristik : BT.709
Matrixkoeffizienten : BT.709
Originales Quellmedium : Blu-ray
mczocker32
Post by mczocker32 » Tue Sep 22, 2026 9:44 am
So I guess I found the problem, maybe someone has a permanent solution.
The playlist file, as well as the actual track 00922.m2ts are identified by MakeMKV and should produce a file around 497.6 MB in size. It does not. MakeMKV recognizes a single video track while the actual m2ts file appears to contain two video tracks. One black screen track in 1080p and a second track in 720x528 containing the actual video
Ezatoka
Post by Ezatoka » Tue Sep 22, 2026 9:48 am
Sounds like a Picture-in-Picture track. MakeMKV drops the second video track upon muxing.
MKVToolNix can open the 00457.mpls as well and you can mux a MKV file with all video tracks inside.
mczocker32
Post by mczocker32 » Tue Sep 22, 2026 10:04 am
Ezatoka wrote: Tue Sep 22, 2026 9:48 am Sounds like a Picture-in-Picture track. MakeMKV drops the second video track upon muxing.
It shouldn't be a picture in picture track. Its only the second video on the disc as well, also the first videotrack really is completly blank. I generated a short script to check for two track files and produce mkvs without the first track.
Ezatoka
Post by Ezatoka » Tue Sep 22, 2026 10:13 am
It also shouldn't be MBAFF, because I don't think I've seen an Interleaved BluRay track within my collection (except for Extras which were taken from a previous DVD release, but they're also 720x576, not 1920x1080)
