Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
DaywalkerNL
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Hello, i just found it with google =)
i want to ask ,can my device read 4k blu rays ? many thanks for the Information
Laufwerksinformation
OS-Gerätename: G:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-S09
Revision: 1.34
Serienummer: OJDL020125WL
Firmware-Datum: 2016-04-25
Highest AACS version: 76
Drive platform: RS8600
Firmware version: 1.34/ID43
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.34
PM sent.DaywalkerNL wrote: Mon Sep 21, 2026 2:28 pm Hello, i just found it with google =)
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.34
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlyDaywalkerNL wrote: Mon Sep 21, 2026 2:28 pm Hello, i just found it with google =)
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.34
see below for email
elfaham
It's my 1st post too. And I got the same drive:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.10
Serial number: XXXXXX
Firmware date: 2013-10-15
Firmware version: 1.10/ID43
OS device name: F:
Revision: 1.10
sure email me that info and all others email me no need to post your info here just reach out to me directlyelfaham wrote: Sun Sep 27, 2026 3:14 am Hello,
OS device name: F:
Revision: 1.10
see below for email
PM sent.elfaham wrote: Sun Sep 27, 2026 3:14 am Hello,
OS device name: F:
Revision: 1.10
bumsvallera
UHD Blu-ray reading my Pioneer BDR-S09
I would like to enable UHD Blu-ray reading on my Pioneer BDR-S09 if possible.
My drive information:
OS device name: /dev/sr0
Revision: 1.34
Firmware date: 2016-04-25
Could you please advise whether this drive is compatible and provide the appropriate firmware and flashing instructions?
Thank you!
Revision: 1.34
Thank you!
Re: UHD Blu-ray reading my Pioneer BDR-S09
Please tell me which OS you use and which hardware (ARM or Intel). Then I will send the right package.bumsvallera wrote: Thu Oct 22, 2026 5:35 pm Hello,
Revision: 1.34
Thank you!
Sure just email mebumsvallera wrote: Thu Oct 22, 2026 5:35 pm Hello,
Revision: 1.34
Thank you!
With this exact subject line
Pioneer FW + Flasher Request
And you will receive the flasher and fw for free within 5 minutes
Joris222
Could someone help me enable UHD reading on my Pioneer BDR-S09XLT?
My drive information from MakeMKV is:
Model: Pioneer BDR-S09XLT
Revision: 1.34
It reads ordinary Blu-rays but does not recognise UHD discs. Is a suitable firmware modification available for this drive, and how can I obtain the correct flasher?
Thank you,
Joris222
Revision: 1.34
Thank you,
Joris222
Sure just email meJoris222 wrote: Thu Oct 29, 2026 3:25 pm Hello,
Revision: 1.34
Thank you,
Joris222
trevbot
Hi Joris, I make trev.bot. It can flash the S09 for UHD too, with a GUI on Windows, Mac and Linux. You can check your drive for free before buying a license: https://trev.bot/pioneer/bdr-s09
