I flashed a ASUS BW-16D1X-U, and it ripped my copy of Disclosure Day but after that the drive will not read any discs.
This is the Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: KLZP99G4442
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Highest AACS version: 77
Firmware version: 3.02
Bradd
Flashing issues
Re: Flashing issues
remove all power from the drive for 5 mins then power backup and try againBradd wrote: Sun Sep 20, 2026 1:48 am I flashed a ASUS BW-16D1X-U, and it ripped my copy of Disclosure Day but after that the drive will not read any discs.
Bradd
this is very common on lg and asus rebrand drives
Bradd
Re: Flashing issues
Thanks Billycar11, I'll try that.
Bradd
Bradd
Bradd
Re: Flashing issues
Hey Billycar11, That didn't work.
Bradd
Bradd
Bradd
Re: Flashing issues
Hey Billycar11, Should I remove the drive from the case, and install it in my PC?
Bradd
Bradd
Re: Flashing issues
what case is it in?Bradd wrote: Sun Sep 20, 2026 5:37 pm Hey Billycar11, Should I remove the drive from the case, and install it in my PC?
Bradd
but sure wont hurt to try seen case psus die
and sadly sometimes cases kill drives i have moved now to not recommending cases
Bradd
Re: Flashing issues
It's a Asus Turbo Drive. The Drive has a Egreen label on it.
Bradd
Bradd
thehamburger
Re: Flashing issues
Hallo,
sorry for jumping into this tread, but I have the same issue with my LG BH16NS55 with ASUS BW-16D1HT Firmware 3.02. After months of working flawlessly and making backups of Bluray- and UHD-Disks, the drive suddenly and unexpectedly lost its ability of reading those media. It started after I ripped a DVD successfully. Since then, only DVD are recognized and can be processed with makemkv.
My Drive Information are as follows:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: K97I4B85244
Highest AACS version: 82
Any help would be highly appreciated.
Gerhard
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Gerhard
Bradd
Re: Flashing issues
I wonder if I remove it from the case, it may work again.
I think it's dead in the water.
Billycar11 do you have drives for sale.
Bradd
Bradd
Re: Flashing issues
Try cleaning the lasersthehamburger wrote: Mon Sep 21, 2026 9:07 am Hallo,
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Gerhard
thehamburger
Re: Flashing issues
Thank You, its certainly worth a try
