Pioneer BDR-UD03 UHD possibility
richardwu
Re: Pioneer BDR-UD03 UHD possibility
Hi Coopervid, possible to PM the solution for converting BDR-XD08LE to be able to rip 4K UHD? Thank you!
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlygrybsh wrote: Sat Sep 19, 2026 4:52 pm Hi!
I have this drive, and I'd like it to read UHD disks.
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.11 Serial number: ************* Firmware date: 2018-11-28 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
see below for email
Please post your Makemkv info.richardwu wrote: Sun Sep 20, 2026 5:02 pm Hi Coopervid, possible to PM the solution for converting BDR-XD08LE to be able to rip 4K UHD? Thank you!
