Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
kazuhiro
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
プリフラッシュ済み Pioneer BDR-XD08B USB C with BDR-XD08-UMBS ファームウェア PayPal フラッシュ、テスト済み、出荷済み MakeMKV for UHD で動作。を購入したいのですがどのようにすればよろしいのですか?
Dbowley
@Billycar11 I am currently in the market for a UHD drive. Specifically Pioneer BDR-S13UBK or BDR-2213 with old/compatible firmware, tested for UHD ripping in MakeMKV. I know these are rare, if these are not available point me in the direct of a drive that you would recommend that is just as good. I'm aware you recommend the pioneer through previous threads. However, I am open to recommendations.
Best thing to do is email me for the links and follow here or reddit for when the drives go loveDbowley wrote: Fri Sep 18, 2026 1:22 am @Billycar11 I am currently in the market for a UHD drive. Specifically Pioneer BDR-S13UBK or BDR-2213 with old/compatible firmware, tested for UHD ripping in MakeMKV. I know these are rare, if these are not available point me in the direct of a drive that you would recommend that is just as good. I'm aware you recommend the pioneer through previous threads. However, I am open to recommendations.
Lordbubbly
Hi. Where do I go to buy one from you? I appreciate your time as well
Email me at the email belowLordbubbly wrote: Sun Sep 20, 2026 6:51 pm Hi. Where do I go to buy one from you? I appreciate your time as well
To get the links so you can buy soon as they go up
