Flashing issues
Bradd
Flashing issues
Post by Bradd » Sun Sep 20, 2026 1:48 am
I flashed a ASUS BW-16D1X-U, and it ripped my copy of Disclosure Day but after that the drive will not read any discs.
This is the Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: KLZP99G4442
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Highest AACS version: 77
Firmware version: 3.02
Bradd
Re: Flashing issues
Post by Billycar11 » Sun Sep 20, 2026 6:03 am
Bradd wrote: Sun Sep 20, 2026 1:48 am I flashed a ASUS BW-16D1X-U, and it ripped my copy of Disclosure Day but after that the drive will not read any discs.
Bradd
remove all power from the drive for 5 mins then power backup and try again
this is very common on lg and asus rebrand drives
Bradd
Re: Flashing issues
Post by Bradd » Sun Sep 20, 2026 5:02 pm
Thanks Billycar11, I'll try that.
Bradd
Bradd
Re: Flashing issues
Post by Bradd » Sun Sep 20, 2026 5:26 pm
Hey Billycar11, That didn't work.
Bradd
Bradd
Re: Flashing issues
Post by Bradd » Sun Sep 20, 2026 5:37 pm
Hey Billycar11, Should I remove the drive from the case, and install it in my PC?
Bradd
Re: Flashing issues
Post by Billycar11 » Mon Sep 21, 2026 12:37 am
Bradd wrote: Sun Sep 20, 2026 5:37 pm Hey Billycar11, Should I remove the drive from the case, and install it in my PC?
Bradd
what case is it in?
but sure wont hurt to try seen case psus die
and sadly sometimes cases kill drives i have moved now to not recommending cases
Bradd
Re: Flashing issues
Post by Bradd » Mon Sep 21, 2026 1:33 am
It's a Asus Turbo Drive. The Drive has a Egreen label on it.
Bradd
thehamburger
Re: Flashing issues
Post by thehamburger » Mon Sep 21, 2026 9:07 am
Hallo,
sorry for jumping into this tread, but I have the same issue with my LG BH16NS55 with ASUS BW-16D1HT Firmware 3.02. After months of working flawlessly and making backups of Bluray- and UHD-Disks, the drive suddenly and unexpectedly lost its ability of reading those media. It started after I ripped a DVD successfully. Since then, only DVD are recognized and can be processed with makemkv.
My Drive Information are as follows:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: K97I4B85244
Highest AACS version: 82
Any help would be highly appreciated.
Gerhard
Bradd
Re: Flashing issues
Post by Bradd » Mon Sep 21, 2026 8:50 pm
I wonder if I remove it from the case, it may work again.
I think it's dead in the water.
Billycar11 do you have drives for sale.
Bradd
Re: Flashing issues
Post by Billycar11 » Mon Sep 21, 2026 10:29 pm
thehamburger wrote: Mon Sep 21, 2026 9:07 am Hallo,
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Gerhard
Try cleaning the lasers
thehamburger
Re: Flashing issues
Post by thehamburger » Tue Sep 22, 2026 3:01 pm
Thank You, its certainly worth a try
