I tried looking around and wasnt seeing anything but was curious as to if this drive is possible to get LibreDrive on? Drive info below
Product: BD-RE WH12LS39
Revision: 1.03
Serial number: K82BCDE0631
Firmware date: 2013-11-06 12:34:56
Bus encryption flags: 1F
Highest AACS version: 66
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.03-D0
WH12LS39 LibreDrive?
Re: WH12LS39 LibreDrive?
Too old, sorry.Ejmj0611 wrote: Wed Sep 16, 2026 6:16 pm I tried looking around and wasnt seeing anything but was curious as to if this drive is possible to get LibreDrive on? Drive info below
Revision: 1.03
rowon
Thanks for the clarification. Is there any particular firmware version or similar LG drive model that would be worth looking for if LibreDrive support is the goal?
Check here but all are hard to get these days.rowon wrote: Thu Sep 17, 2026 10:04 pm Thanks for the clarification. Is there any particular firmware version or similar LG drive model that would be worth looking for if LibreDrive support is the goal?
viewtopic.php?t=19634
And here is the seller section if you can't find any in a retail store:
viewforum.php?f=20
