WH12LS39 LibreDrive?
Ejmj0611
Post by Ejmj0611 »
I tried looking around and wasnt seeing anything but was curious as to if this drive is possible to get LibreDrive on? Drive info below
Product: BD-RE WH12LS39
Revision: 1.03
Serial number: K82BCDE0631
Firmware date: 2013-11-06 12:34:56
Bus encryption flags: 1F
Highest AACS version: 66
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.03-D0
Re: WH12LS39 LibreDrive?
Ejmj0611 wrote: Wed Sep 16, 2026 6:16 pm I tried looking around and wasnt seeing anything but was curious as to if this drive is possible to get LibreDrive on? Drive info below
Revision: 1.03
Too old, sorry.
rowon
Post by rowon »
Thanks for the clarification. Is there any particular firmware version or similar LG drive model that would be worth looking for if LibreDrive support is the goal?
rowon wrote: Thu Sep 17, 2026 10:04 pm Thanks for the clarification. Is there any particular firmware version or similar LG drive model that would be worth looking for if LibreDrive support is the goal?
Check here but all are hard to get these days.
viewtopic.php?t=19634
And here is the seller section if you can't find any in a retail store:
viewforum.php?f=20
Echolinna
Post by Echolinna »
If LibreDrive support is not feasible for my drive, are there alternative solutions or software that could provide similar functionality?
gwhitcombe71
Post by gwhitcombe71 »
echolinna, to be fair i reckon the honest answer is theres no proper software-only workaround... the whole point of LibreDrive is the drive itself doing the heavy lifting, so with an older drive youre stuck with whatever the stock firmware can manage (which for newer discs is alot less than youd hope). I hit the same wall last year and in the end just grabbed a used compatible drive off ebay for about thirty quid (checked the list on here first, bloody glad i did). Have a look at the seller section Coopervid linked, its definately cheaper than faffing about for weeks.
