andidHayder wrote: Wed Sep 16, 2026 2:29 am
Billycar11 wrote: Tue Sep 15, 2026 10:28 pm
andidHayder wrote: Tue Sep 15, 2026 4:33 pm I have a WP50NB40 svc NB52 that I am trying to flash using a Mac. From what I understand I need to follow this path for flashing
however when I click the link it says "The selected attachment does not exist anymore." and in the all you need firmware pack it only has BP60NB10-1.02. Has it been moved somewhere and I am just missing it? Thanks
Follow the boot code recovery section for nb52
When following that guide do I still need to include the -f path/to/sdf.bin from the other Mac commands or is that not needed with the boot code recovery method? It wasn’t in the windows commands but just wanted to make sure it wasn’t a platform difference as I was translating the commands.
Also thanks to both of you! :)
that may be needed on mac
yuppie
Post by yuppie »
If anyone can point me to a good driver to buy, let me know. My main requirement is that it's external and has a USB connector.
fullrecovery
Post by fullrecovery »
Another newbie here looking to flash my drive for uhds. I already downloaded makemkv, sdftool flasher and the all you need firmware files. Just need some guidance of which firmware to flash it to. New to this, thanks.
Buffalo BRXL-16U3 external
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 8.53
Serial number: houdini
Firmware date: 2019-03-07
Highest AACS version: 12
Drive platform: RS8F00
Firmware version: 8.53/ID52
fullrecovery wrote: Wed Sep 16, 2026 7:21 pm Another newbie here looking to flash my drive for uhds. I already downloaded makemkv, sdftool flasher and the all you need firmware files. Just need some guidance of which firmware to flash it to. New to this, thanks.
OS device name: F:
Revision: 8.53
PM sent.
fullrecovery
Coopervid wrote: Wed Sep 16, 2026 7:39 pm PM sent.
Thank you! Ripping The Matrix 4k right now. Seamless.
OS device name: F:
Revision: 8.53
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
nurmdog
Post by nurmdog »
I just bought an Asus BC‑12D2HT "New" from Taiwan. It works great on Linux with BR and DVD, but not UHD. In Windows it has the same results, no UHD support. I read this guide but I am unsure on what flashing to do to get UHD support.
Revision: 1.0
Drive Platform: MT 1939
Firmware Version: 1.0
Advice?
Sayaka
Post by Sayaka »
Drives with the MT1939 platform will never be able to read UHD discs.
nurmdog wrote: Thu Sep 17, 2026 3:48 pm I just bought an Asus BC‑12D2HT "New" from Taiwan. It works great on Linux with BR and DVD, but not UHD. In Windows it has the same results, no UHD support. I read this guide but I am unsure on what flashing to do to get UHD support.
Revision: 1.0
Advice?
That aint' new!! The MT1939 drive platform was prior to 2015 so it is 11+ years old. The advice is to return it!!
nurmdog
Post by nurmdog »
Thanks, and that stinks. I used "points" off my credit card to get it, so it was about $10 of "real" money, but it sucks I can't read 4k movies. I only have 2 UHD discs, but it means I will have to save up for another drive at some point.
nurmdog wrote: Fri Sep 18, 2026 3:21 pm Thanks, and that stinks. I used "points" off my credit card to get it, so it was about $10 of "real" money, but it sucks I can't read 4k movies. I only have 2 UHD discs, but it means I will have to save up for another drive at some point.
Considering both LG & Pioneer no longer manufacture drives and the OEM supplies (ASUS, Verbatim, Buffalo, Archgon) are about to dry up, you might want to hurry up before they are all gone!
Bad_Thunder74
Post by Bad_Thunder74 »
Hello!
I would like to make my Pioneer BDR-209D UHD capable. Could you please provide the correct flash kit for my drive?
Drive Information:
Product: BD-RW BDR-209D
Revision: 1.50
Firmware date: 2017-12-21
LibreDrive Information:
Drive platform: RS8601
Firmware version: 1.50/ID61
Thank you!
