that may be needed on macandidHayder wrote: Wed Sep 16, 2026 2:29 amWhen following that guide do I still need to include the -f path/to/sdf.bin from the other Mac commands or is that not needed with the boot code recovery method? It wasn’t in the windows commands but just wanted to make sure it wasn’t a platform difference as I was translating the commands.Billycar11 wrote: Tue Sep 15, 2026 10:28 pmFollow the boot code recovery section for nb52andidHayder wrote: Tue Sep 15, 2026 4:33 pm I have a WP50NB40 svc NB52 that I am trying to flash using a Mac. From what I understand I need to follow this path for flashing
however when I click the link it says "The selected attachment does not exist anymore." and in the all you need firmware pack it only has BP60NB10-1.02. Has it been moved somewhere and I am just missing it? Thanks
Also thanks to both of you!![]()
yuppie
If anyone can point me to a good driver to buy, let me know. My main requirement is that it's external and has a USB connector.
fullrecovery
Another newbie here looking to flash my drive for uhds. I already downloaded makemkv, sdftool flasher and the all you need firmware files. Just need some guidance of which firmware to flash it to. New to this, thanks.
Buffalo BRXL-16U3 external
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 8.53
Serial number: houdini
Firmware date: 2019-03-07
Highest AACS version: 12
Drive platform: RS8F00
Firmware version: 8.53/ID52
OS device name: F:
Revision: 8.53
PM sent.fullrecovery wrote: Wed Sep 16, 2026 7:21 pm Another newbie here looking to flash my drive for uhds. I already downloaded makemkv, sdftool flasher and the all you need firmware files. Just need some guidance of which firmware to flash it to. New to this, thanks.
OS device name: F:
Revision: 8.53
fullrecovery
Thank you! Ripping The Matrix 4k right now. Seamless.
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlyfullrecovery wrote: Wed Sep 16, 2026 7:21 pm Another newbie here looking to flash my drive for uhds. I already downloaded makemkv, sdftool flasher and the all you need firmware files. Just need some guidance of which firmware to flash it to. New to this, thanks.
OS device name: F:
Revision: 8.53
see below for email
nurmdog
I just bought an Asus BC‑12D2HT "New" from Taiwan. It works great on Linux with BR and DVD, but not UHD. In Windows it has the same results, no UHD support. I read this guide but I am unsure on what flashing to do to get UHD support.
Revision: 1.0
Drive Platform: MT 1939
Firmware Version: 1.0
Advice?
Revision: 1.0
Advice?
Sayaka
Drives with the MT1939 platform will never be able to read UHD discs.
That aint' new!! The MT1939 drive platform was prior to 2015 so it is 11+ years old. The advice is to return it!!nurmdog wrote: Thu Sep 17, 2026 3:48 pm I just bought an Asus BC‑12D2HT "New" from Taiwan. It works great on Linux with BR and DVD, but not UHD. In Windows it has the same results, no UHD support. I read this guide but I am unsure on what flashing to do to get UHD support.
Revision: 1.0
Advice?
nurmdog
Thanks, and that stinks. I used "points" off my credit card to get it, so it was about $10 of "real" money, but it sucks I can't read 4k movies. I only have 2 UHD discs, but it means I will have to save up for another drive at some point.
Considering both LG & Pioneer no longer manufacture drives and the OEM supplies (ASUS, Verbatim, Buffalo, Archgon) are about to dry up, you might want to hurry up before they are all gone!nurmdog wrote: Fri Sep 18, 2026 3:21 pm Thanks, and that stinks. I used "points" off my credit card to get it, so it was about $10 of "real" money, but it sucks I can't read 4k movies. I only have 2 UHD discs, but it means I will have to save up for another drive at some point.
Bad_Thunder74
Hello!
I would like to make my Pioneer BDR-209D UHD capable. Could you please provide the correct flash kit for my drive?
Drive Information:
Product: BD-RW BDR-209D
Revision: 1.50
Firmware date: 2017-12-21
LibreDrive Information:
Drive platform: RS8601
Firmware version: 1.50/ID61
Thank you!
Drive Information:
Revision: 1.50
Thank you!
vdbnt
Hi there,
I would like to make my PIONEER BDR-US03 UHD capable. Could you please provide the correct flash kit for my drive?
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Firmware date: 2018-08-22
Drive platform: RS8511
Firmware version: E101/ID26
Many thanks in advance!
Manufacturer: ASUS
Revision: E101
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlyBad_Thunder74 wrote: Sat Sep 19, 2026 9:43 am Hello!
Drive Information:
Revision: 1.50
Thank you!
see below for email
PM sent.Bad_Thunder74 wrote: Sat Sep 19, 2026 9:43 am Hello!
Drive Information:
Revision: 1.50
Thank you!
