Updating firmware on HL-DT-ST BD-RE WH14NS40
rubiks1
Post by rubiks1 »
Hello
I want to update the firmware on my HL-DT-ST BD-RE WH14NS40 drive to read UHD. I downloaded the all in one software pack and do not see the firmware for the HL-DT-ST BD-RE WH14NS40 however I do see the one for HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.
Is there another firmware I need to use?
Drive info
OS device name: /dev/sr2
Product: BD-RE WH14NS40
Revision: 1.05
Serial number: REDACTED
Highest AACS version: 82
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Sayaka
Re: Updating firmware on HL-DT-ST BD-RE WH14NS40
Post by Sayaka »
This is the correct firmware to flash. Flash it with encryption (rawflash enc).
rubiks1
Post by rubiks1 »
I tried it and it received an error.
Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_KLZP2AD2229
5% ..
Write DRAM NG 00/00/00
Command produced error code 0x82000000
Sayaka
Post by Sayaka »
If you've already made sure there was no disc inside the drive when you flashed, try connecting your drive to a different port, or replacing the cable.
rubiks1
Post by rubiks1 »
Tried that same issue. Is that the correct firmware? I have a WH14NS40 and I am flashing HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.
Sayaka
Post by Sayaka »
The firmware is the correct one. I am surprised that replacing the SATA cable (or trying a different port) didn't work. This error code is also identical to the one some people get with Archgon (i.e., non-flashing-compatible) enclosures, but that shouldn't be the case here, right ?
EDIT : Also, make sure the tray is closed, but you probably already did that...
rubiks1
Post by rubiks1 »
I grabbed another sata cable,moved it to another port and rebooted the machine. A little finicky but IT WORKED!!
Output below. Going to test it now.
Thanks for all of the help!!
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
