Asus BW-16D1X-U
Andy_01
Asus BW-16D1X-U
Post by Andy_01 »
Hi, can anyone please help. Is this drive able to be patched to read 4K?
If so could you please advise what flash utility to use and which firmware?
Thank you!
Andy
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
Re: Asus BW-16D1X-U
See guide below or email me or Marty for an automated flasher
Andy_01
Re: Asus BW-16D1X-U
Post by Andy_01 »
Thank you! As it turns out I took a chance and used the SDFTool Flasher v1.36 and Firmware WH16NS60-1.02
Worked like a charm.
oap1ikwydlsh2o
Re: Asus BW-16D1X-U
Post by oap1ikwydlsh2o »
hi , which software di u use please
OneDay
Re: Asus BW-16D1X-U
Post by OneDay »
I used SDFTool 1.36
Used Firmware BW-16D1HT 3.10
Worked perfectly since it is a Asus drive.
oap1ikwydlsh2o
Re: Asus BW-16D1X-U
thank you , worked forst time .
zittrig
Re: Asus BW-16D1X-U
Post by zittrig »
OneDay wrote: Mon Mar 02, 2026 8:12 am I used SDFTool 1.36
To avoid the Sleep Bug or have less problems with 3-Layer discs feel free to flash to LG WH16NS60 1.02MK.
OneDay
Re: Asus BW-16D1X-U
Post by OneDay »
oap1ikwydlsh2o wrote: Mon Mar 02, 2026 9:50 am thank you , worked forst time .
Glade it worked
Also as zittrig said flash the LG WH16NS60 1.02MK
The drives in the BW-16D1X-U are rebranded LG WH16NS40 from what I have researched.
bob1273
Re: Asus BW-16D1X-U
Post by bob1273 »
Hey there,
so if I have a new ASUS BW-16D1X-U, which Firmware should I flash to - the LG WH16NS60 1.02MK ?
Thanks in advance
Re: Asus BW-16D1X-U
bob1273 wrote: Tue Sep 15, 2026 11:12 am Hey there,
Thanks in advance
depends if its mt1959 see guide or email me or marty for an auto flasher
if its pioneer email me for the automated flasher see profile for email
Re: Asus BW-16D1X-U
Thanks in advance
Post your Makemkv info as plain text.
bob1273
Re: Asus BW-16D1X-U
Post by bob1273 »
Well, I ordered it, but there are some availability problems und I did not get it yet. As soon as I receive the drive I will post the information, thanks.
