So I was reading up and the drive I have may be possible to flash to read 4K discs. Here is the information I have, and I know the drive is early 2015, so not sure if it will still apply to mine. Any info would be great, thanks in advance.
Pioneer BD-RW BDR-209M
MFD: January 2015
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.20
Serial number: OADL010166WL
Firmware date: 2014-04-08
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 1.20/ID60
Re: Pioneer BD-RW BDR-209M
PM sent.MakerMan101 wrote: Mon Sep 14, 2026 11:16 pm So I was reading up and the drive I have may be possible to flash to read 4K discs. Here is the information I have, and I know the drive is early 2015, so not sure if it will still apply to mine. Any info would be great, thanks in advance.
MFD: January 2015
Revision: 1.20
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlyMakerMan101 wrote: Mon Sep 14, 2026 11:16 pm So I was reading up and the drive I have may be possible to flash to read 4K discs. Here is the information I have, and I know the drive is early 2015, so not sure if it will still apply to mine. Any info would be great, thanks in advance.
MFD: January 2015
Revision: 1.20
see below for email
MakerMan101
I got a PM, from the person above with the files. Thanks for the reply as well.Billycar11 wrote: Tue Sep 15, 2026 11:39 am sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
I only posted all that info, because someone before asked about their drive and someone mentioned to provide the relevant info and to paste the text from MakeMKV drive info and libredrive info sections. So just to be helpful I posted it.
So how are you helpful? You missed the message.MakerMan101 wrote: Tue Sep 15, 2026 7:55 pmI got a PM, from the person above with the files. Thanks for the reply as well.Billycar11 wrote: Tue Sep 15, 2026 11:39 am sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
MakerMan101
As far as me being helpful with me posting my MakeMKV info, so you didn't have to ask for it.
