Public KeyDB Disc Submissions
gibbon
Post by gibbon » Sat Sep 12, 2026 4:06 am
Disc type: UHD
Disc ID: 0xA33E2A6CF0D9A73C9BE70E13847931AD0181ACE0
Disc dump filename: MKB20_v82_Hunt_For_The_Wilderpeople_CA26
Drive: Pioneer BDR-S12U
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1PYt4ab ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1BjcZkn ... sp=sharing
GFly91
Post by GFly91 » Sat Sep 12, 2026 7:00 am
The Mandalorian and grougu dump submitted.
https://drive.google.com/file/d/1J5CRjn ... sp=sharing
MKVDUDE
Post by MKVDUDE » Sat Sep 12, 2026 10:36 am
Another batch please - All files are in the same link -https://we.tl/t-xtrYFUsW00jAK2dE
Disc type: BD
Disc ID:3f6737ffef8f57907c40c185e549baec28aa6bf8
Disc dump filename:MKB_v82_CLASH_OF_THE_TITANS_(1981)_-_EXTRAS_89D4.tgz
Drive: MT1959
Drive firmware: 1.03
MKB_RO.inf link:https://we.tl/t-xtrYFUsW00jAK2dE
Disc dump link:https://we.tl/t-xtrYFUsW00jAK2dE
Disc type: UHD
Disc ID:3e36357b58981e311e8c1f8e77e063976e846016
Disc dump filename:MKB20_v82_CLASH_OF_THE_TITANS_(1981)_-_UHD_42D8.tgz
Drive: MT1959
Disc type: BD
Disc ID:bc98dc6582ade4a762f72124025323d49e69f8a2
Disc dump filename:MKB_v82_THE_DIRTY_DOZEN_EXTRAS_8CF4.tgz
Drive: MT1959
Disc type: UHD
Disc ID:d05794e04a9e82a6ff900fa9e3b6f98f167f2ee6
Disc dump filename:MKB20_v82_THE_DIRTY_DOZEN_-_UHD_913C.tgz
Drive: MT1959
Disc type: UHD
Disc ID:dea6a28f697981694dad7f608041f2fce75470b1
Disc dump filename:MKB20_v82_FARGO_-_UHD_3AC0.tgz
Drive: MT1959
Disc type: UHD
Disc ID:49df9977525814d4cc6be6a437da48ae51c41aea
Disc dump filename:MKB20_v82_WARGAMES_F41E.tgz
Drive: MT1959
Many thanks!
keydb_helper
Post by keydb_helper » Sat Sep 12, 2026 11:21 am
Thanks to everyone who followed the template and provided new disc dump files. The following BD and UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v77_Avatar-_The_Way_of_Water_A2E3
*MKB20_v82_CLASH_OF_THE_TITANS_(1981)_-_UHD_42D8
*MKB20_v82_FARGO_-_UHD_3AC0
*MKB20_v82_Hunt_For_The_Wilderpeople_CA26
*MKB20_v82_THE_DIRTY_DOZEN_-_UHD_913C
*MKB20_v82_THE_MANDALORIAN_AND_GROGU_66BC
*MKB20_v82_WARGAMES_F41E
*MKB_v82_CLASH_OF_THE_TITANS_(1981)_-_EXTRAS_89D4
*MKB_v82_THE_DIRTY_DOZEN_EXTRAS_8CF4
BigBoySmoke69 wrote: Sat Sep 12, 2026 12:06 am Disc ID:3E5AA5E800C392CCEFEC9922C82DA2D8FA3B7BE3
Disc dump filename:MKB20_v82_Batman-_Knightfall_Part_1_9AB2.tgz
Thanks for following the submission template BigBoySmoke69 but your disc was added to the public keydb on September 8. It would be appreciated if you could try out the latest keydb before posting to this thread.
RandomSelf wrote: Wed Sep 02, 2026 6:01 pm Disc type : UHD
Disc ID : B94E464A827D69D6A57331B847B7D2F047BDDCB8
Disc dump filename : MKB20_v82_BLU-RAY_UHD_2E0E
RandomSelf wrote: Wed Sep 02, 2026 6:02 pm Disc type : UHD
Disc ID : CB3F38B9D3998D93EA16F65F70F6F995DEDF0555
Your links have expired. If you'd like to see support added for your discs, post new links to this thread. If you continue to post disc dumps to title-specific threads they will probably keep being overlooked.
KeyDB Download
BigBoySmoke69
Post by BigBoySmoke69 » Sat Sep 12, 2026 12:57 pm
keydb_helper wrote: Sat Sep 12, 2026 11:21 am Thanks to everyone who followed the template and provided new disc dump files. The following BD and UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
I tried to add it to makemkv but the page keeps failing to load fvonline-db.bplaced.net/
But the disc now worked on make mkv today unlike yesterday.
ncbreezy
Post by ncbreezy » Sat Sep 12, 2026 1:25 pm
Disc type: UHD
Disc ID: 0xe6719946632fa245c0d6aa818d36f8e0e1fa212c
Disc dump filename: MKB20_v82_Charlie_Wilson's_War_E7E8
Drive: MT1959
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1QVrCns ... sp=sharing
Disc dump link: https://drive.google.com/file/d/10E18i9 ... sp=sharing
keydb_helper
Post by keydb_helper » Sun Sep 13, 2026 2:15 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_Charlie_Wilson's_War_E7E8
*MKB20_v82_I_Know_Where_I'm_Going_92E4
*MKB20_v82_The_Red_Shoes_9A0A
*MKB20_v82_The_Small_Back_Room_219A
*MKB20_v82_The_Tales_of_Hoffmann_ACE0
*MKB20_v82_サムライ_4Kレストア_UHD_95E4
KeyDB Download
rkjnsn
Post by rkjnsn » Sun Sep 13, 2026 8:01 am
Disc type: UHD
Disc ID: 0x057703D12AEADDF4FED8266C437245425C55DD18
Disc dump filename: MKB20_v72_Tangled_17A9.tgz
Drive: BP50NB40
Drive firmware: BU40N 1.00 (OmniDrive v1.0.4)
MKB_RO.inf and dump link: [edit: done]
keydb_helper wrote: Fri Jul 24, 2026 5:07 pm Hey rkjnsn, I believe MrPenguin and a few other Linux users have had success with FindVUK via Wine. I don't have any saved links or notes but you might be able to find some instructions on this forum or possibly Doom9.
Thanks for the tip! I've been able to use
FindVUK.exe Synchronize
via wine to keep a local copy updated and
FindVUK.exe ValidateDisc
to turn all of my discs into validated entries (as well as add new entries where an existing media key or (for standard Blu-ray) device key works for the disc). It appears FindVUK.exe uses a built-in key to sign all submissions, so it seems there is indeed no way to submit without using that binary.
keydb_helper
Post by keydb_helper » Sun Sep 13, 2026 4:41 pm
rkjnsn wrote: Sun Sep 13, 2026 8:01 am Disc ID: 0x057703D12AEADDF4FED8266C437245425C55DD18
Thanks for including the full MKB_RO.inf file with your submission. Your disc has been added to the public keydb.
rkjnsn wrote: Sun Sep 13, 2026 8:01 am Thanks for the tip! I've been able to use
to turn all of my discs into validated entries...
I'm glad to hear you've established a good workflow. It would be great if more users could make a habit of validating keydb entries with FindVUK.
KeyDB Download
sweetroll
Post by sweetroll » Sun Sep 13, 2026 6:01 pm
Disc type: UHD
Disc dump filename: MKB20_v82_Out_of_the_Past_E48E.tgz
Drive: BD-RE WH16NS60
LibreDrive status: enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1tFxFfV ... drive_link
Disc dump link: https://drive.google.com/file/d/1h_0k5P ... drive_link
keydb_helper
Post by keydb_helper » Mon Sep 14, 2026 12:08 am
sweetroll wrote: Sun Sep 13, 2026 6:01 pm Disc type: UHD
Thanks for the submission sweetroll. Your disc has been added to the public keydb.
KeyDB Download
paintedman
Post by paintedman » Mon Sep 14, 2026 3:40 am
Disc type: UHD
Disc ID: 0xEDFADF5190E0A202D89E827AE35F9EAE2595CCBF
Disc dump filename: MKB20_v82_交渉人_真下正義_C5DE
Drive: BD-RE BU40N
Drive firmware: OmniDrive 1.0.4
MKB_RO.inf link: https://gofile.io/d/2FCxtXcF
Disc dump link: https://gofile.io/d/fompeP8K
HEHAHE
Post by HEHAHE » Mon Sep 14, 2026 7:11 am
Disc type: BD
Disc ID: 0xDE1203723BD1068CDFFB8A8F4D33D714203638BE
Disc dump filename: MKB_v82_BD_ROM_F698
Drive: ASUS SBW-06D2X-U
Drive firmware: A102
LibreDrive status: Possible, not enabled
MKB_RO.inf link:https://drive.google.com/file/d/14BTzMv ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1GxB-nw ... sp=sharing
HEHAHE
Post by HEHAHE » Mon Sep 14, 2026 7:20 am
Disc type: BD
Disc dump filename: MKB_v82_BD_ROM_2F5E
MKB_RO.inf link:https://drive.google.com/file/d/1riFDdr ... sp=sharing
Disc dump link: https://drive.google.com/file/d/125S_rk ... sp=sharing
Post by MartyMcNuts » Mon Sep 14, 2026 8:05 am
HEHAHE wrote: Mon Sep 14, 2026 7:20 am Disc type: BD
The latest version of MakeMKV should be able to decrypt AACS v82 standard blu-ray discs.
