Asus BW-16D1X-U Platform RS8600 Firmware Flashing?
joseguerrero
Re: Asus BW-16D1X-U Platform RS8600 Firmware Flashing?
Post by joseguerrero »
Hi Coopervid,
I have an ASUS BW-16D1H-U with the following details:
Firmware revision: E114
Firmware version: E114/ID71
Drive platform: RS8601
Firmware date: 2017-12-21
LibreDrive: Enabled
I would like to crossflash it to the correct S11 / RS8801 firmware for this RS8601 hardware.
Could you please send me the appropriate flasher and firmware package, and let me know the recommended procedure?
I want to make sure I use the correct RS8801/S11 V2 firmware and avoid anything intended for RS8800.
Thank you very much for your help.
joseguerrero wrote: Sun Sep 13, 2026 8:20 pm Hi Coopervid,
LibreDrive: Enabled
PM sent.
joseguerrero wrote: Sun Sep 13, 2026 8:20 pm Hi,
LibreDrive: Enabled
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
Wanbao
Post by Wanbao »
Hello Coopervid,
First of all, thank you for all the time and effort you dedicate to helping members of the MakeMKV community. I really appreciate the work you do and your willingness to share your expertise.
I recently joined the forum after researching how to enable UHD Blu-ray ripping on my ASUS BW-16D1H-U external drive.
My drive currently works perfectly with regular Blu-rays, but it does not recognize UHD 4K discs.
Here are the details reported by MakeMKV:
Drive: ASUS BW-16D1H-U
Firmware: E114/ID71
LibreDrive status: Enabled
I came across your posts helping other members with this exact configuration, and I understand that a modified Pioneer BDR-S11 V2 firmware may allow UHD ripping.
Would you be kind enough to help me with the appropriate firmware and flashing procedure for my drive?
I would also appreciate any advice on precautions to take before flashing, as I would obviously like to avoid damaging a drive that is otherwise working perfectly.
Thank you very much for your time and for everything you contribute to the community.
Best regards
szat74
Post by szat74 »
Posting here because this seems to be the place to get help with RS8600 drives. Coopervid, are you able to help me flash the following drive so I can read/rip UHD disks?
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: -------------------
Firmware date: 2015-10-20
Highest AACS version: 47
Drive platform: RS8600
Firmware version: E101/ID76
Sure just email me
With this exact subject line
Pioneer FW + Flasher Request
And you will receive the flasher and fw for free within 5 minutes
everyone else please dont spam this just reach out to the appropriate people we dont want to have to respond to all if you with the same thing
see pinned guide below
Wanbao wrote: Mon Oct 26, 2026 8:47 pm Hello Coopervid,
Firmware: E114/ID71
Best regards
PM sent.
szat74 wrote: Thu Oct 29, 2026 11:03 pm Posting here because this seems to be the place to get help with RS8600 drives. Coopervid, are you able to help me flash the following drive so I can read/rip UHD disks?
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
PM sent.
WG356
Post by WG356 »
Hoping to update my drive. been working well for some time but from what I have read it should be capable of reading UHD but needs an updated flash. could you point me in the right direction. Information on my drive below. Thank you.
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: QEDL123186WL
Highest AACS version: 76
mattjackson86
Post by mattjackson86 »
You could go to a 211M which supports UHD
https://freemkv.org/firmware/find/?driv ... ision=E102
duromx
Post by duromx »
First of all, Many many many thanks for the effort of this team and its great work
I have the next drive, and I would like to know if it's capable to read/rip UHD discs.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: NLDL086223WL
Firmware date: 2018-05-08
Bus encryption flags: 13
Firmware version: 1.51/ID61
Thank You in advance!
duromx wrote: Wed Nov 04, 2026 2:28 pm First of all, Many many many thanks for the effort of this team and its great work
Revision: 1.51
Sure just email me
Wanbao
Post by Wanbao »
Coopervid wrote: Fri Oct 30, 2026 11:27 am
Firmware: E114/ID71
Best regards
PM sent.
Big thanks to Coopervid!
Successfully crossflashed my ASUS BW-16D1H-U (E114) to Pioneer BDR-S11 1.53. Everything went smoothly and the drive is working perfectly!
Thanks a lot for your help, really appreciate it!
