Role Models Failing.
Heliosone
Post by Heliosone » Fri Jul 27, 2018 8:24 am
New disc. clean disc. Gets about 20% in then:
DEBUG: Code 45045000 at n]b0~$o-o?V5vbG:khR:121265821
DEBUG: Code 0 at 7(:bJRPje>S[z:y!Z~".~:121267661
Failed to save title 1 to file X:/Movies/Role Models.mkv
runtimeterror
Re: Role Models Failing.
Post by runtimeterror » Tue Jul 31, 2018 3:44 pm
Same here for Star Trek BluRay. This worked once for the first disc (lots of error messages but good result) but now fails with:
MakeMKV v1.12.3 linux(x64-release) started
Saving 1 titles into directory /home/kai/Videos/Star_Trek_Season_1_Disc_1
AV synchronization issues were found in file '/home/kai/Videos/Star_Trek_Season_1_Disc_1/Star_Trek_Season_1_Disc_1_t00.mkv' (title #1)
AV sync issue in stream 1 at 0:00:00 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +9.708ms
AV sync issue in stream 2 at 0:00:00 with duration of 32ms : 3 frame(s) dropped to reduce audio skew to +9.708ms
AV sync issue in stream 3 at 0:00:00 with duration of 32ms : 3 frame(s) dropped to reduce audio skew to +9.708ms
AV sync issue in stream 4 at 0:00:00 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +9.708ms
AV sync issue in stream 1,2,3,4 at 0:00:00 with duration of 41.708ms : encountered overlapping frame, audio skew is +9.708ms
DEBUG: Code 45045000 at F{k2j:Zg"ss#rLdJ4HE:121265821
DEBUG: Code 0 at NJk{MT7/%Ii.}RGNB5hUD:121267661
Failed to save title 0 to file /home/kai/Videos/Star_Trek_Season_1_Disc_1/Star_Trek_Season_1_Disc_1_t00.mkv
Running on a freshly installed Linux Mint with an external "techPulse120"-Drive ("BD-RE MATSHITA BD-MLT UJ240AF 1.01"). Freshly compiled ffmpeg.
Lovely Rita
Post by Lovely Rita » Tue Jul 31, 2018 5:27 pm
runtimeterror wrote:Same here for Star Trek BluRay. This worked once for the first disc (lots of error messages but good result) but now fails with:
You should have posted a new topic “Star Trek.......” since this one concerns the movie Role Models. :wink:
Registered User :wink:
Buy MakeMKV
runtimeterror
Post by runtimeterror » Tue Jul 31, 2018 11:06 pm
Oh, sorry! I wasn't aware those threads were disc-specific.
Annihilation
Post by Annihilation » Fri Sep 11, 2026 8:07 pm
Anyone ever find a workaround on this disc for Role Models?
