sound missing, bluray
zumosol
#1 Post by zumosol » Wed May 09, 2012 7:44 pm
Hi:)
Movie: Hangover 2
In VLC Sound is missing.
In Dvbviewer both sound and Sub's are missing + movie plays in a kind of slowmotion.
Picture quality looks fine in both players.
I have tried to search for information about the subject but have not found anything, only I should use latest ffmpeg, so I downloaded, but nothing changed.
The "funny" thing is if I try a BD's I recorded some time ago sound works and sub's also
Any idea what else could cause the problem?
Any other information you need to answer?
thanx:)
Added later:
I tried to set audio to lossless in MakeMkv, and now I have sound using VLC, but sub's disapeared... ?!?!?
In Dvbviewer picture was still slowmotion, and sound ..well.. and then I disabeled ac3filter and speed and sound became normal, but sub's are missing.
so the only problem left is subtitles... in VLC and Dvbviewer. they ARE recognized in MakeMKV !.
zumosol
Re: sound missing, bluray
#2 Post by zumosol » Fri May 11, 2012 7:43 pm
hello :D
..after a week with a million try's and adjustings and so on I found a solution, MAYBE some of it is overkill, but I'm too tired to try to delete some of it just to see if it all is nesseary...
so in case anyonoe else out there is fighting same problems as me.. :
install DA-player
http://www.digiarty.com/
download from dvbviewer's homepage, Members section http://dvbviewer.com/en/index.php : postprocessor
downlaod haali matroska: http://haali.su/mkv/
download DirectVobSub: http://www.free-codecs.com/download/directvobsub.htm
downlaod CCCP ffmpeg:http://www.cccp-project.net/
download LAV codecs here: http://www.codecs.com/download/LAVFSplitter.htm ( it also comes with latest Dvbviewer version I think, not sure actually :) )
use LAV videodecoder for all types decoders in Settings/Options/Directx in Dvbviewer
restart PC !!
go into haali from start menu in Windows:options/compability/ and: load Vsfilter =YES
if it don't work then get drunk... smash your PC :twisted: and buy a bluray stand-alone player..
Ps I'm absolutely not sure DA-player is nesseary, BUT it can play back both MKV and Bluray disc's directly, with any further adjustments than downloading it,
and you know..I'm too lazy to delete it, just to see if MKV files works without it or not :)
cheers! :mrgreen:
PS sometimes I miss VHS... "plug" in a tape press play and it worked..computers have NOT made life easier..really not.. on the other hand it was not HD..
zumosol
#3 Post by zumosol » Fri May 11, 2012 10:45 pm
nxt problem:
Sound is 2 channel stereo. And can not be changed as far as I can see
If I try to use Ac3-filter as ac3 decoder, the MKV movie begin to play in fast forward.. not slowmotion this time..
If I use LAV, normal speed but two channel stereo.
should i laugh or what? :lol:
maybe sleep..
crowfax
#4 Post by crowfax » Fri May 11, 2012 10:58 pm
Smithcraft
#5 Post by Smithcraft » Sat May 12, 2012 4:20 am
What does MediaInfo show for the file attributes?
SC
zumosol
#6 Post by zumosol » Sat May 12, 2012 6:13 pm
Smithcraft wrote:What does MediaInfo show for the file attributes?
SC
this is what is says for audio, and looks like it is fine:
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 1h 41mn
Bit rate mode : Variable
Bit rate : 1 561 Kbps / 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : Lossless
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 1h 41mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.07 GiB (6%)
Title : 3/2+1
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 41mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 466 MiB (2%)
Title : 3/2+1
Language : English
Default : No
Forced : No
zumosol
#7 Post by zumosol » Sat May 12, 2012 6:15 pm
crowfax wrote:Try sMplayer:
http://smplayer.sourceforge.net/
Will look at it later :)
but prefer I only use one software, and Dvbviewer can be used with TV cards also, so that's why...
