Weird behaviour from Pioneer drives.
babayaga
Post by babayaga »
There might have been a mishappen on the flashing front, even though i don't have any clue how it could've happen, but right now my XD08 only reads DVDs, not BluRay (and of course not uhd) with last firmware 1.04. This also happens to my XD05 (curently not connected and dont remeber the firmware version, but i think it also is passed the 12/22 cut off point. Anyone knows about this? I tried to force flash my XD08 with offical 1.04 firmware, but that doesn't work out of the box no more. Any help would be great. Or at least some insight in why they are doing this, both drives read DVD btw, but nothing else.
Re: Weird behaviour from Pioneer drives.
If you put the drives in kernel mode you can flash the lastest fw over them
But i have Not seen that on any of my pioneers
Did you do anything that would trigger this?
babayaga
Post by babayaga »
Billycar11 wrote: Tue Sep 08, 2026 2:48 pm If you put the drives in kernel mode you can flash the lastest fw over them
Yes, once tried to update the firmware on this XD08 drive, and used the officall firmware updater, i used https://pioneer.jp/cgi-bin/device/downl ... W104EU.exe for firmwarea. I have tried to flash it again using my own flasher, since the offical flasher won't do it - and it seemed ok, but now my drive is in constant kernel mode, and i can't get out of it. Maybe the kernel was sent ok, but the normal firmware wasn't, or even a CRC-error somewhere?
| DRIVE INFORMATION |
Drive : \\.\H: |
Vendor : PIONEER |
Model : BD-RW BDR-XD08 |
Firmware : 0000 |
Type : CD/DVD/BD optical |
Removable : Yes |
SCSI ver : 0 |
Platform : SAT 9330ID36 |
Kernel : ID36 |
Buffer : 2000 KB |
Max read : 0 KB/s (~0x CD) |
Mech type : Other |
Write cap : CD-R=N CD-RW=N DVD-R=Y |
Disc : No disc (0x0000) |
Have you seen this in your workings with post 12/22 drives?
C:\firmware2>drivekit.exe flashfw H --file S9330000.104 --file2 S9330001.104 --nounlock
     █░██ ██░▌ Drive Kit v1.0           cPix / Razor 1911 (c) 2026
     █░██■██▀  Optical drive research toolkit
Opened: \\.\H:
=== FLASH FIRMWARE ===
  Do you want to dump current firmware before flashing? [Y/n]: n
  Do you want to proceed with flashing? [y/N]: y
  Checking no disc...
  No disc - OK
  File : S9330000.104
  Size : 0x11200 bytes (full file including header)
  WARN : SAT 8801 not found in header
  Type : Kernel confirmed
  Drive    : ID=0x9330  HW=SAT 9330ID3
  Firmware : HW=SAT 9330
  Platform : SAT 9330ID3 -> SAT 9330 (crossflash allowed)
  Drive ID : compatible (0x9330 vs 0x9330)
  [DBG] platform="SAT 9330ID36" driveID=0x9330
  Payload  : PIONEER BDR-BDS8 + key
[0a/3] Checking drive ready...
  READY
[1/3] Unlock skipped (--nounlock)
  Pre-flash: reading 0xF1...
  Pre-flash: reading 0xA0...
    WARNING: 0xA0 read returned sense key 05 ASC=24
[2/3] Sending kernel (single transfer, 70144 bytes)...
  70144 / 70144 bytes - OK
  Done.
[2c/3] Sending firmware (S9330001.104)...
  Type : Normal confirmed
  1913088 / 1913088 bytes
  Done.
[2d/3] Execution trigger (mode=5, bufID=0xFF)...
  Status: GOOD
[2a/3] Waiting for flash to complete...
  GET EVENT 80/80
  TUR   1/120: skey=00 ASC=00  Flash complete - drive ready (no disc)
babayaga
Post by babayaga »
I tried using BDRFlash to flash the two firmware files S9330000.104 and S9330001.104 - it reports the firmware has a bad checksum, but from what i can see they seem fine, is there an alternative site to downloading firmware files?
You can not flash official fw from dumped/extracted fw of pioneer updaters
In bdr flash
babayaga
Post by babayaga »
Billycar11 wrote: Tue Sep 08, 2026 9:09 pm You can not flash official fw from dumped/extracted fw of pioneer updaters
In bdr flash
well, that explains it! :) But you are familiar with these cut off drives, it does at least flash when i send the firmware, but can it be flashed to the same firmware as it had? i mean, XD08 is 1.04, and i tried to flash that, but it seems that only the kernel are active, when i boot the drive im in kernel mode (the flash mode), and that's about it, can't get out of kernel mode or anything, at least i wish i could use the drive for bluray and dvd, until i have the means to pay you for flashing, although not sure if you can do it when my drive is in limbo? :)
I have never had a drive that was acting like this so
Not sure we will be able to fix it
I would think it would but not 100% sure
babayaga
Post by babayaga »
Billycar11 wrote: Tue Sep 08, 2026 9:46 pm I have never had a drive that was acting like this so
I completely understand! Actually i did flash my ad07 with firmware from the updater.exe - worked just fine :)
